HP 840 G1 is not in committed state
+ More Options
Posts
  • gabry120
    • Nov 2019
    • 38
    • italia
    Hello! I have HP 840 G1, i changed motherboard and i could fill serial number, SKU ecc...I locked MPM and everythings ok, but i have always "Warning: Machine is not in committed state" error on bootup, how can I clean it? I've tried Brand11,12,13,14 but doen't work.
    Thank You very much.
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    Re: HP 840 G1 is not in committed state
    You need to to clean the me region.post your dump here.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      It has got nothing to do with me region. You still have some missing dmi info.
      • gabry120
        • Nov 2019
        • 38
        • italia
        But after i used NbDmiFit i don't have Product Information Not Valid" error message and dmi info are correct.
        • RethoricalCheese
          • Mar 2013
          • 1518
          • Estonia
          Same problem with 820 G2.
          Main bios was deleted so I took clean BIOS region (from HP website) and clean ME, stitched them together and programmed main bios. First it had no DMI data and then it retrieved it from EC bios. All data was present and correct.
          Only "Warning: Machine is not in committed state" remained.
          • gabry120
            • Nov 2019
            • 38
            • italia
            Here you are
            • RethoricalCheese
              • Mar 2013
              • 1518
              • Estonia
              I have one 840 G1 which had "ME state in recovery mode".
              Replaced ME region with clean ME. Now it says "Warning: Machine is not in committed state" instead.
              • bachir2004
                • Feb 2015
                • 439
                • maroc
                Post your full dump.full dump is 16 mb.
                • gabry120
                  • Nov 2019
                  • 38
                  • italia
                  And how can i do full dump?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    By reading your eeprom chip with a bios programmer. you need to desolder the bios chip.
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      No, you don't need to desolder it.
                      Unplug battery.
                      Plug in charger.
                      Turn the laptop on (and go to bios or whatever, doesn't matter).
                      Turn the laptop off but DO NOT remove charger.
                      Connect soic8 clip to eeprom and read bios.
                      This way it almost always reads without a problem. Otherwise the programmer might not even recognize eeprom.
                      • Akintunde
                        • Mar 2017
                        • 154
                        • Nigeria
                        [QUOTE=RethoricalCheese;925511]No, you don't need to desolder it
                        Unplug battery.
                        Plug in charger.
                        Thanks for this information.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Unplug battery.
                          Plug in charger.
                          I dont prefer this method as there are models where soic8 clip doesnt read bios properly when taken in circuit-Why leave room for confusion when it hardly takes 5 mins to do the job.
                          • RethoricalCheese
                            • Mar 2013
                            • 1518
                            • Estonia
                            Verification takes care of that problem, dont you use it?
                            Elitebooks handle hot air station without a problem but probooks dont. It isnt 5 minutes anymore if disassembly is needed.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Verification i always do and my programmer is set that way only. All mobo's can handle heat if you do things nicely. If probook mobo's cant bear a hot air station , then how do we change IC's on those.
                              See, the point is everyone one of us do repairs in their own way. Something which i dont prefer is not the norm. One can always disagree.
                              • RethoricalCheese
                                • Mar 2013
                                • 1518
                                • Estonia
                                Not the mobos, I meant the plastic housing doesnt take heat well on probooks. It starts melting instantly. Thus I would need to disassemble the laptop before using hot air on mobos which takes way more than 5 minutes.
                                Using my method to read eeprom on-board works pretty much always and if it doesn't, it will let you know.
                                If you want to waste time, it is on you. Whatever you prefer. But saying that it reads incorrectly is just not right. Yes if you just connect the soic8 clip and try to read, it mostly doesn't work but when you turn the laptop on and off and then try reading, it works very well almost always. If it doesn't work, the programmer will let you know about it.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Sir, i never said it reads incorrectly. Re-read my post again. i said on some motherboards it doesnt reads properly. Does that mean -"it reads incorrectly" always. Why'nt read the statement in whole "there are models where soic8 clip doesnt read bios properly" Any way lets not argue unnecessarily.
                                  • gabry120
                                    • Nov 2019
                                    • 38
                                    • italia
                                    This is full dumb, or i hope so!
                                      • 21032
                                      Try this bios .
                                      • smiley60
                                        • Jul 2021
                                        • 43
                                        • UAE
                                        Originally posted by SMDFlea
                                        Try this bios .
                                        Hi sir can u do this for me plz
                                        its the dump of 840 g1
                                        • sc84647
                                          HP Elitebook 840 G3 - "Machine is not in committed state"
                                          by sc84647
                                          Hi
                                          I have an EliteBook 840 G3 that boots with "Machine is not in committed state!", the system info is correct when displayed in the BIOS screen:
                                          Serial Number : 5CG6481F5D
                                          Product Number : L3C65AV
                                          Description : HP EliteBook 840 G3
                                          I've tried using the BiosConfigUtility.exe from HP BCU (SP143621) which says MPM is in Lock state, and if I try changing that using that tool I get:
                                          <SETTING changeStatus="fail" name="Manufacturing Programming Mode" reason="Access Denied" returnCode="6">
                                          <OLDVALUE><![CDATA[Lock]]></OLDVALUE>
                                          02-11-2024, 08:27 AM
                                        • suny99
                                          HP 650 G1 (Your machine is not in committed state)
                                          by suny99
                                          I have HP 650 G1 which was bricked.
                                          Bricked file is attached: backup.zip
                                          Using CH431A I was successful in flashing .bin that I have found here on forum
                                          (file attached PROBOOK 650G1.zip)
                                          But the problem was that there was error message:
                                          After that white screen with listed items:
                                          Product name
                                          Product serial number
                                          Product SKU
                                          Product family
                                          CT number
                                          Using MPM tool I was able to add all of the listed items (Can't say I'm sure that I did...
                                          06-01-2022, 04:50 PM
                                        • darksideofthemoon
                                          Hp Elitebook 820 G1 "warning!! machine is not in committed state"
                                          by darksideofthemoon
                                          I bought a new motherboard for my HP Elitebook 820 G1 but the warning error appears when I turn it on"
                                          I realized that since it was a virgin card, some data was missing... I took it from the notebook's plate and inserted it with a tool found online but the error remains. I can't find the BUILD ID (not even on the partsurfer site). Is there a way to recover it? I also have a bios backup from the previous card, could I recover it from there? Thanks and sorry for the bad English
                                          10-08-2023, 10:02 AM
                                        • pcproffsen
                                          Elitebook 850 G1 "machine is not in committed state"
                                          by pcproffsen
                                          What are the Brands about?
                                          Which one is for what PC model?
                                          I have a Elitebook 850 G1, with the problem "machine is not in committed state" showing at boot.
                                          But I can login to Bios, and everything looks ok there. And no hardware is changed.
                                          I also updated to latest Bios version.
                                          So I just dont understand why this message shows, how can I get rid of it?...
                                          03-30-2023, 11:43 AM
                                        • Kamus291
                                          HP 650 G1 - machine not in committed state
                                          by Kamus291
                                          I have an HP 650 G1
                                          Motherboard was changed but I do not have backup of old BIOS
                                          I get "machine not in committed state" when laptop starts
                                          CPU is over heating. I do not know if related.
                                          Tried BIOS from below link. Laptop do not boot.
                                          https://www.badcaps.net/forum/showpo...00&postcount=7
                                          I get "MPM is not unlocked", when using "HP Manufacture Programming MPM Unlock tool down"
                                          See attached BIOS, CT from new board and serial number of laptop
                                          Can someone please...
                                          03-07-2023, 12:37 PM
