SN: C02SV4QKH3QD
Name: MacBook Air (13-inch, Early 2015)
Model: A1466
EMC: 2925
I looked for the motherboard revision but couldn't locate one.
EFIBIN File MacBook Air A1466 (EMC 2632) 820-3437-B
Hello All,
I made a mistake when recovering from a broken bios chip. I followed the instructions from page 1 and didn't realize it's a different EMC number. Mine is a 2925 and the one I put on was for a 2632. So I'm assuming that's why I'm getting a black screen. Is the EMC number something I need to change in the hex editor and reflash or is it completely different? I already followed the guide to put in my SN and fix the checksum.
post S/N, full name and model, motherboard model,EMC,etc.Leave a comment:
Hello All,
this is working with display... May i ask if i have problem w this file because it cannot detect the storage device.. Or fo i need my original dump file to be clean.. I use ot to my no display unit.. It goes to good with display but cant detect ssd drive... Is it ok to use to other unit with same board number..Leave a comment:
HI BROTHERS PLEASE CLEAN THIS FOR ME
LOCKED FILE -mb -820-3437-B
C02N5MPDG086Leave a comment:
try..Attached FilesLeave a comment:
hi need clean file for this
a1466
Serial Number: FVFVH26BJ1WK
HI tryAttached FilesLeave a comment:
Can someone help me Clean ME the bios firmware for this.
MacBook Air A1466
EMC:2925
SN: FVFSQ19EH3QD
I truly appreciate your help.
Thank you so much.Attached FilesLeave a comment:
I leave this here to give back a little of what the community has done for me. It worked well for me in one that could not read the SSD or read it slowly.Leave a comment:
by psdavid65I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by echothegamerHello all,
Working on my wife's 13' Macbook air. It's been in a box since she upgraded but I figured it could be good practice.
Details:
Macbook 13' A1466
Board (820-3209-A)
Battery OEM 7.3v 50Wh 6700 mAh (020-7379-A)
Pictures below of Boardview and schematic...
I don't know how to test the voltage on a MacBook battery. I just assumed it had an enable pin but the best I could read was 300 something mV poking around the battery connector.
It's an older model and it is very likely that battery has become... -
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by dbuergiHi all,
i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
Any ideas where to look?... - Loading...
