MacBook 2019 - Efi - SCBO file
  • biospwd
    Banned
    • Oct 2019
    • 51
    • Ireland
    Someone help me generate SCBO for this macbook 2019 ??
    Hash here: https://privnote.com/1Pk49ZJQ#gXGglMxwL
    I saw @imranromi on this board can generate this. Please help.
  • biospwd
    Banned
    • Oct 2019
    • 51
    • Ireland
    Re: MacBook 2019 - Efi - SCBO file
    Nobody can help? @imranromi ?
    New Link for Hash:
    https://privnote.com/MbrcCQLG#27IB4iKTT
    • madjid911
      • 390
      • France
      hi, please, how to removed the password uefi for macbook a2159
      • KvnTM
        • May 2018
        • 434
        Open a new thread. Don't hijack old / other peoples threads please.
        • bouch
          unlock macbook air A1932 2019
          by bouch
          hi
          i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
          i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
          i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
          have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
          I need help or information?
          Does anyone have the minat2 activator 1.4 software?
          Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
          Thank yo...
          03-12-2025, 10:14 AM
        • kenzo2
          Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
          by kenzo2
          I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
          I need dump file MACBOOK PRO A2159
          TSB4232(256)
          TSB4229(256)
          Thanks​
          01-11-2025, 04:18 AM
        • alfredodinolfo
          MacBook Pro 2019 (A1990)
          by alfredodinolfo
          mb code:820-01827-A;
          sn:C02Z349ALVDR;
          i9 32GB Ram 1TB
          Hi, I found short on one of 6 black nand (total 1TB).
          i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
          I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
          macbook with A2141 configuration run on recovery but don't complete it.​
          anyone can help me?
          05-26-2025, 09:27 AM
        • mferna14
          820-01521-A (MacBook Air A1932 2019) stuck on 5V
          by mferna14
          Hi all dear friend., today I am working on 820-01521-A logic board (MacBook Air A1932 2019) stuck on 5V .19 milliamps. The history of this logic board was liquid spill on major components. First gave a good cleanup & both CD3215C00Z were getting very hot, so I replaced both. Now on the 12V coil, there is only 5v present & 3.3V is perfect. In some area like PPVIN_G3H_P3V3G3HRTC , PPBUS_G3H_TPAD etc., 12V is perfect. On the 5v coil .2 volts only. I checked the enable signal on the regulator chip, enable is NOT present. The logic board is very clean, I do not see any signs of spill anymore....
          03-27-2025, 04:52 PM
        • Karmet
          MacBook Pro 16" 2019 NAND Swap
          by Karmet
          I couldn't find a post related to this, so if it exists please point me in that direction.
          I have a 2019 MacBook Pro 16" 1TB with a dead embedded NAND. I've seen some information about how it is possible to swap NANDS from certain boards, but it has to be a matching set.
          I have a MacBook Pro 2017 logic board 820-00923-A 1TB on hand that is new in the box. It should be possible to match up the NAND 0, 1, 2, 3 chips and transplant them onto this 2019 board... in theory. Has anyone approached this, or has success in doing this?
          07-24-2023, 10:48 AM
