hp probook 450 g2 bios lock
  • Haker5
    Banned
    • Mar 2015
    • 65
    • internet
    please remove bios password from my dump
  • biospwd
    Banned
    • Oct 2019
    • 51
    • Ireland
    Re: hp probook 450 g2 bios lock
    Unpass in dump. If you see notice ,,warning machine is not commite'' you need restart laptop few time (6-7) then data should be load and notice disappear.
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      This one is easier to use.
      • DAIMON_
        • Jun 2022
        • 3
        • Italia
        Unlock bios password from hp probook 450 g2
        Can anyone please remove the password from this bios?
        I'm trying milions of methods but none work
        If anyone can help me to remove this password i would be very grateful.
        I tried for example to insert another BIOS through the programmer ch341a but after that the computer does not recognize the hard disk.
          • 22010
          Re: Unlock bios password from hp probook 450 g2
          Have you tried RCUnlocker
          https://www.badcaps.net/forum/showthread.php?t=103526
          • DAIMON_
            • Jun 2022
            • 3
            • Italia
            i will try it later, thanks for now
            • faresbouafia
              • Dec 2020
              • 23
              • algerian
              HP Probook 450 G2 password
              please help me for unlock password HP Probook 450 G2
              • hardware1
                • Sep 2021
                • 2948
                • N/A
                Re: HP Probook 450 G2 password
                Try with RCUnlocker Tool:
                https://www.badcaps.net/forum/showthread.php?t=98539
                all donations are welcome,
                • LS97
                  • Oct 2024
                  • 3
                  • Netherlands
                  I've tried unlocking my password protected BIOS with RCunlocker but it says no unlockable content.
                  Would someone be able to help unlock the BIOS?
                  HP Probook 450 G2
                  Thanks in advance!
                • LS97
                  • Oct 2024
                  • 3
                  • Netherlands
                  Apologies, Please see below:
                  Serial: CND4282VJT
                  Product: J4T68ES#ABH
                  PCID: A3008DD10B03
                  • peste
                    • Dec 2016
                    • 13662
                    • ROMANIA
                    Serial: CND4282VJT
                    PCID: A3008DD10B03
                    post the bios of the laptop, not the update from the website
                    • LS97
                      • Oct 2024
                      • 3
                      • Netherlands
                      The file I've attached on my original post has been created with the BIOS utility from HP using the backup option. So it's not the BIOS update file from HP. It's a backup from the BIOS of the actual laptop.
                      • peste
                        • Dec 2016
                        • 13662
                        • ROMANIA
                        ok... the bios you posted is 6MB, the original bios of the laptop is 8MB...you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
