Request unlocked Satellite L55t-A bios
  • aleksmatilda
    • Oct 2019
    • 3
    Model Name Satellite L55t-A
    Part Number PSKLJU-00G009
    Serial Number 7D159716Q
    OS Version Microsoft Windows 10 Pro 10.0.17763
    BIOS Version 1.80
    Thanks in advance
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Request unlocked Satellite L55t-A bios
    Try this virgin bios from toshiba.
    PS:Always post corrupt bios when you request for a bios.
    • aleksmatilda
      • Oct 2019
      • 3
      Thank you, i will nxt time.
      Can you explain to me what kind of bios VIRGIN is?
      its stand for ?
      Also, the current bios in laptop works great for me, however i just want to look at what other options are hidden behind stock bios and burn off the computer after a couple of igp overclocks
      ONE MORE QUESTION
      2nd laptop is ASUS k73e and i would like to know is posible to DISABLE motherboards IGP via unlocked bios and use Intel i5 graphics only, or is better way to convert to uma?-ofc i asking this bcs i think ur expirenced guy
      thks in advance
      and again thanks for bios
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Virgin bios means a bios made from manufacturer's web update bios file and its not a dump from some machine-so it should work if there are no other issues. A virgin bios usually have a clean me, no dmi data like serial number etc and windows key.
        your 2nd question- Usually a bios mod dont convert a mb from dis to uma though there are few such boards where you have a option in bios to switchover from dis to uma. Physical conversion is the best choice if its possible on that platform and you may have to flash bios for uma version in some cases.
        PS: There are more experienced members here then me and i myself still learning from them.
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
        • hotcrossedbuns999
          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
          by hotcrossedbuns999
          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
          3. I could only locate two chips that look like bios chips. Could someone verify this
          01-03-2025, 12:32 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
