---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters.
Do not hijack threads! Look at the thread title. Post in existing related thread, or if there is no any for your model create a new one. Also add serial number, SNID, full model name...
---------------------------------------------------------------------------------------------------------------------------------------------------------- All donations to Badcaps are welcome. Become a Badcaps supporter >>>>>click on this link to donate <<<<< Thanks to all supporters. ----------------------------------------------------------------------------------------------------------------------------------------------------------
[QUOTE=rojocapo;964660]Hi I have an Acer E5-575-51GG and I had to replace the mobo with a used spare bought on eBay. New replacement motherboard does not detect keyboard and touchpad after the BIOS has taken control. I am able to press F2 to go into the BIOS config menu, but then the keyboard stops working. If I attach an external USB keyboard+mouse I can operate the computer but obviously that would not make sense for a laptop.
Could someone check if something can be done to this dump to fix the keyboard issue? I read above that someone had to update their EC. How is that done?
That just happened to me that the keyboard or the touchpad did not work, I could only enter the bios but from there no key worked, the same thing that happened to the one in the commentary and I solved it, I programmed the bios and the kbc and nothing was the same The solution was to change the wireless network card is the one that causes this problem. I'll comment on it in case something similar happens to you, first change the network card before doing anything else. I already had that laptop for a month and I couldn't find the fault. and it turns out that it is something very simple I hope and someone will find the solution
I can't see myself out with this model. Issue is a black screen, I tried to flash 4 different BIOS BINs already. Obviously this model was sold with many different specification, original ACER BIOS also contains four different versions.
all donations are welcome,
>>>>>click on this link to donate via PayPal.<<<<<
Every donation made will go towards server fees and maintenance costs. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------
