Absolute Persistence Module (HP Computrace)
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    Does anybody know more about this? If I remember correctly, it is something like Computrace and it is not located in bios.
    Is there a way to remove it?
    Just in case adding bios dump.
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    Re: Absolute Persistence Module (HP Computrace)
    Anybody?
    Looks like I forgot to rar it so it did not upload.
    Here is the dump file.
    • torrevieja
      • Mar 2018
      • 6
      • Ukraine
      Hi! How to disable Absolute Persistence Module in Hp 450 g7 ?
      • RethoricalCheese
        • Mar 2013
        • 1517
        • Estonia
        You could try contacting Absolute to get them to remove this device from their server. But only if the device is not marked as lost/stolen.
        • anhbanxoi
          • Sep 2021
          • 169
          • VN
          Do we have any method to disable this Absolute by modifying BIOS?
          • yodafett
            HP 820 G3 Absolute Persistence Module
            by yodafett
            Hi, It's been a while since I've messed with this laptop so my memory may not be 100% correct,
            Current Absolute settings are listed bellow.
            "Absolute Persistence Module Current State
            Activation Status: Inactive
            Absolute Persistence Module Permanent Disable: No"
            I would like to be ride of the Absolute all together if possible or at least be able to change " Permanent Disable to "Yes". Am I correct in thinking that "Permanent Disable No" means that it can be activated remotely at any time?
            07-21-2021, 09:01 AM
          • Mr.Ultimate
            Dell Precision 5540 - Absolute / Computrace permanently enabled. Need bios fix to disable
            by Mr.Ultimate
            Hi, I have Dell precision 5540 laptop from old workplace,decommissioned old stock. its a good spec laptop i9-9880H etc, so I decided to keep it and use it for personal purposes.
            I was checking bios settings and I found that Absolute (Computrace) is permanently enabled/activated, and field is grayed out, unable to change it to disabled/deactivated state. The laptop status is clean, absolute has no any warnings or messages booting pre-bios pre-OS or post booting, while using laptop, im just not feeling safe having absolute permanently enabled having backdoor on a bios level enabled to my...
            08-06-2024, 05:24 AM
          • saygi
            Lenovo ThinkPad T14s Gen2 Disable Absolute Persistence Module
            by saygi
            Hello, everyone.
            I've brought this laptop of gumtree it was sold under 'spare or parts' the only issue with the laptop was it tends to heat up after 2-3 hours and decrease in performance.
            because it did not come with a hdd I could not test it there, so I've installed a hdd and put windows 10 on it, I've used it for 5 hours and it did not heat up or decrease in performance however it turned off and displayed a message saying this laptop is disabled. I couldn't enter bios or boot windows at all. so I removed the hdd and reinstalled windows again and the message is...
            11-19-2023, 06:30 AM
          • mnetobr
            Lenovo Thinkpad E14 Gen 5 Absolute / Computrace
            by mnetobr
            Hello everyone, please I need help to disable absolute on this equipment. Thanks
            ThinkPad E14 Gen 5
            NM-F351
            21JSS2MM00...
            04-10-2025, 12:22 PM
          • williaan
            Tutorial and Guide to Remove Absolute/Computrace
            by williaan
            I would like to learn how to clean Absolute. Where can I find guides and tutorials? I also want to help this community.
            03-29-2025, 06:41 AM
