re-dell vostro 3560 bios
  • inkman
    • Sep 2019
    • 55
    I need ec and main bin files please. I have attached my back up (faulty) bios.
    Vostro 3560- service tag -40c80x1
    Motherboard QCL00 LA-8241p/ REV1.0(A00)
  • crowntoy99
    • Oct 2012
    • 267
    • india
    Re: re-dell vostro 3560 bios
    try this
      • 22109
      Your 2MB bin is corrupt. Try these .
      • inkman
        • Sep 2019
        • 55
        Thank you for bin files.
        I have flashed both bios chips,varified 100%.
        When i tried to start laptop its dead.I press power button there is no led lights
        no dvd lights,no fan running.
        I have not been able to flash kb1902.
        How do you flash kb9012 so many pins.
        Can flashing be done with ch341 with added accessory.
        Any advice will be welcomed.
          • 22109
          Yes you can use the CH341A and flashrom to program the KB9012
          http://dangerousprototypes.com/docs/...ith_Bus_Pirate
          Here`s a compiled windows version of flashrom with kb9012 support
          https://winraid.level1techs.com/t/gu...rammer/32948/3
          • Akintunde
            • Mar 2017
            • 154
            • Nigeria
            Dell Vostro 3560
            Good day Everyone, Please i want to unlock this laptop
            • GeorgettaCZ
              • Jun 2018
              • 5
              • Czech Republic
              THANK YOU, SMDFlea!!!!
              I just used your A20 files to recover my friends Vostro. No need to flash the ENE KB9012 chip, jut those two and... voilá!! Up'n'runnin! With i5-3230M, 8GB DDR3@1600MHz and 256GB Samsung Evo SSD, this one is still a fair mobile device!
              THANK YOU!!!
              • dahnking
                • Apr 2018
                • 264
                • kenya
                100% working
                Thank you
                • inkman
                  • Sep 2019
                  • 55
                  dell vostro 3560 bios bin files needed.
                  Motherboard QCL00 LA-8241P
                  REV.1.0 (A00)
                  2012-02-10.
                  Power light comes on, fan spins, it goes through dell diognostic
                  but nothing on screen, screen is blank. Nothing on external.
                  I think it may be bios.
                  Please can anybody share working bios please.
                  I have attached faulty bin files.
                  Thanks in advance.
                    • 22109
                    Re: dell vostro 3560 bios bin files needed.
                    https://www.badcaps.net/forum/showthread.php?t=79676 Post #3 confirmed working .
                    • inkman
                      • Sep 2019
                      • 55
                      vostro 3560 faulty bios.
                      • inkman
                        • Sep 2019
                        • 55
                        I have now fixed my motherboard.
                        Bios file A20 did not work for me. The bios file A17 by
                        MCPLSLG123 worked and my laptop is back to life.
                        I only needed to flash both bios chip and did not need
                        to flash kbc. I also managed to fix 2nd motherboard with similar
                        problem with same bios file.Thank you MCPLSLG123 you are briliant.
                        • leofaria
                          • Sep 2021
                          • 4
                          I have a vostro 3560 that has black screen with one beep continuous. the dell bios update from a15 to a20 does not work says software not compatible.
                          after trying to boot 20 times works
                          the beep code says checksum error.
                          how can I update this bios to the a20. dell site says urgent but does not work o win 10 64 bits
                          I download these bins but no sure how that works. please help
                          • peste
                            • Dec 2016
                            • 13749
                            • ROMANIA
                            post the backup copy of the laptop's original bios
                            • leofaria
                              • Sep 2021
                              • 4
                              I use a couple bios software to backup but they don't recognize the bios
                              bios backup tool kit
                              my bios is insydeh20 a15 bios
                                • 22109
                                my bios is insydeh15 bios
                                Software won`t backup. If you can boot to the bios check the version number,then boot into windows and flash the bios to the next version upthen the next.
                                Check the CMOS battery voltage as well.If you can`t boot up at all buy a programmer and a sop8 clip ,the cheapest is the CH341A .
                                • leofaria
                                  • Sep 2021
                                  • 4
                                  Thanks for the reply. the updated version is a20 from the dell site but when I run the pc will restart and say wrong firmware
                                    • 22109
                                    Try and flash A16 first ,then A17 ,A19 ,then to A20 if you want. Each time you flash you risk bricking the laptop.If it does get bricked then you will need a programmer.
                                    A16 https://dl.dell.com/FOLDER01874731M/1/3560A16.exe
                                    A17 https://dl.dell.com/FOLDER02148905M/1/3560A17.exe
                                    A19 https://dl.dell.com/FOLDER04862241M/1/3560A19.exe
                                    • leofaria
                                      • Sep 2021
                                      • 4
                                      Thanks I will try
                                      edit same error with the a16
                                      • arrow79
                                        • Dec 2021
                                        • PL
                                        Hi All,
                                        i try to upgrade my Vostro360 from A13 and using 4Mb.bin from here i see there's a chance to do that. What i see unfortunately is "The BIOS image must support the ATp!".
                                        What kind of tool it's better to use to upgrade the BIOS on this model?
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          11-14-2025, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • 417731
                                          BIOS needed for Dell Vostro 3405
                                          by 417731
                                          Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                                          Model: Dell Vostro 3405
                                          Tag:F0B1YF3
                                          CPU:Ryzen 3500U
                                          Thanks in advance
                                          07-06-2025, 06:48 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
