Hi, i'm lookin for KBC EC bios for X553SA rev2.0. Anyone? Thanks in advance.
X553SA EC KBC dump needed
Re: X553SA EC KBC dump needed
Here try this one,cut from ver 202 bios update.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank You i think that file is ok but motherboard not booting, there must be some other issue with my board. I compare Yours file with dumped data from freshly installed new ITE and it appears that new EC programmed itself from main bios on first turn. Data from file and my dump are exactly same. Nonetheless Thank You.Comment
Asus laptops always program the kbc on first boot as long as the kbc is blank.Comment
by re-atariHello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he... -
by rednix01Hi everyone,
I accidentally bricked my NUC7i5BNH after disabling the option to boot from USB, and now it's not showing any display at all. I tried the USB recovery method, but unfortunately, it didn't work.
Local repair shops are quoting around $150 just to flash the EEPROM, but considering the unit is only worth about $75 these days, that’s not really an option. So I'm hoping to learn how to flash the chip myself. But to get started, I need a working BIOS dump for the NUC7i5BNH.
I did come across a post with a dump for the NUC7i7BNH, but I wasn't sure...-
by erkko13Ho ho ho, badcaps people,
if this qualifies as bios request, hopefully. Actually BIOS2 for that laptop is second smaller SPI flash (Winbond W25Q80DVSNIG-GP-U), containing supposedly some config for TPS65988 which in turn manages USB-C stuff, including PD. This is possibly flash, where update "Power Delivery Firmware (TI TPS65988)" F407.06.29 -- https://download.lenovo.com/pccbbs/mobiles/r10pd10w.exe does its thing. Previous owner claims that after clean install of Windows 10 he installed thinkvantage tool of sort, which updated everything for that laptop. I did glance over...-
Channel: BIOS Requests ONLY!
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks -
by hirensLenovo ideapad 3 14IGL05 bios dump needed
model: 81wh
sn: pf36ta6h
board no: nm-c961 gs453/gs553
hey guys above is my laptop info
it only blinks the power button kindly help me with a working dump
old dump attached...-
- Loading...
