Llenovo ideapad 320 bios dump
  • bepom
    • May 2019
    • 8
    • bosna i hercegovina
    Re: Llenovo ideapad 320 bios dump
    it works, but it's late in uploading the picture, can you help me?
    • hardware1
      • Sep 2021
      • 2945
      • N/A
      Which file you mean?
      all donations are welcome,
      • abbassink
        • Aug 2015
        • 83
        • iran
        Re: Lenovo ideapad 320 bios dump
        Originally posted by singh.gurpreet61188
        nm-b452 100% working
        its working bios , i test it, 100% ok bios,
        • KazMax
          • Mar 2024
          • Poland
          Hi. I tested this BIOS and works nice but now i dont have any graphic card in system. My MB (NM-B452) have MX150 graphic card (machine type 81BG, 81BT). Propably this BIOS is without VGA BIOS. This is possible? Anyone have correct BIOS file?
            SMDFlea commented
            Editing a comment
            Post the serial number and your original bios backup
            You MUST:
            • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
        • KazMax
          • Mar 2024
          • Poland
          Problem solved. My mistake :/ I forgot make BIOS default settings. After that all be OK
          • Leader
            • Oct 2023
            • Bulgaria
            #26
            work 100% thank you
            • arjhay26
              • May 2021
              • Philippines
              #27
              This File 100% working.. Thank you..
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                by haitham sharabati
                Hello engineers 😀,
                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                💀 Problem:😅
                - Device shows “Administrator Password”...
                08-07-2025, 04:54 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
