Llenovo ideapad 320 bios dump
  • bepom
    • May 2019
    • 8
    • bosna i hercegovina
    Re: Llenovo ideapad 320 bios dump
    it works, but it's late in uploading the picture, can you help me?
    • hardware1
      • Sep 2021
      • 2930
      • N/A
      Which file you mean?
      all donations are welcome,
      • abbassink
        • Aug 2015
        • 83
        • iran
        Re: Lenovo ideapad 320 bios dump
        Originally posted by singh.gurpreet61188
        nm-b452 100% working
        its working bios , i test it, 100% ok bios,
        • KazMax
          • Mar 2024
          • Poland
          Hi. I tested this BIOS and works nice but now i dont have any graphic card in system. My MB (NM-B452) have MX150 graphic card (machine type 81BG, 81BT). Propably this BIOS is without VGA BIOS. This is possible? Anyone have correct BIOS file?
            SMDFlea commented
            Editing a comment
            Post the serial number and your original bios backup
            You MUST:
            • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
        • KazMax
          • Mar 2024
          • Poland
          Problem solved. My mistake :/ I forgot make BIOS default settings. After that all be OK
          • Leader
            • Oct 2023
            • Bulgaria
            #26
            work 100% thank you
            • arjhay26
              • May 2021
              • Philippines
              #27
              This File 100% working.. Thank you..
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                by haitham sharabati
                Hello engineers 😀,
                I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                💀 Problem:😅
                - Device shows “Administrator Password”...
                Today, 04:54 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • MDSI
                HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                by MDSI
                I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                Details:
                Model : HP OMEN 17-an012nf
                Motherboard Part Number : DAG3BAMBAF0 REV : F
                Serial Number (S/N) : 5CD7280D51
                BIOS chip : Winbond W25Q64VSIQ
                Programmer : EZP2023+
                Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                I already...
                07-28-2025, 07:11 AM
