Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
  • ScorpioMan86
    • 94
    • South Africa
    #61
    Re: Lenovo Ideapad 330s Bios Request
    Originally posted by SMDFlea
    Try the bios at post #27. If you can use a hex editor read post #29 ,copy your DMI using the off-sets from your backup to the new bios. If you can`t do it let us know
    Thank you, i managed to edit the bios with my dmi info and the laptop is up and running
    • djharold
      • Aug 2015
      • 246
      • COLOMBIA
      #62
      Re: Lenovo HSB J MV-6 94v-0 E89382 -- 330S_ARR_V06 ---REVV:MP ---- BIOS DUMP PLEASE
      Originally posted by Smeek
      this bios is working for me
      problem solved
      thanks work for me
      • Wilfried
        • Sep 2019
        • 81
        • Cameroun
        #63
        Re: Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
        hello my brothers
        I have an IdeaPad 330s-15arr ryzen7
        his problem is that when i start with the built-in ram it works fine but when i insert the second ram on the slow the machine does not display
        I don't know if it could be a bios problem
        • hoaca388
          Badcaps
          • Jan 2022
          • 12333
          #64
          Originally posted by Wilfried
          hello my brothers
          It's more of a hardware issue than a bios issue but if you want to rule it out you can post the current bios file here.
          ​https://www.badcaps.net/donate
          • Wilfried
            • Sep 2019
            • 81
            • Cameroun
            #65
            hello my brothers
            • hoaca388
              Badcaps
              • Jan 2022
              • 12333
              #66
              hello my brothers
              Try
              • jimore
                • Nov 2020
                • 179
                • mexico
                #67
                Originally posted by claudiomfa
                try and report. Extracted from original
                file
                try help clean this bios ,thanks.
                • omokas
                  • Jun 2021
                  • greece
                  #68
                  Originally posted by mahmoodjavan
                  BIOS
                  7wcn30ww.bin
                  330S_ARR_V06
                  Worked for me thank you! Remember to use 1.8V adapter on programmer
                  • MadeBR
                    • Jan 2023
                    I have the same problem, someone can help me.
                    • peste
                      • 13641
                      • ROMANIA
                      #70
                      try post#2
                      • djharold
                        • Aug 2015
                        • 246
                        • COLOMBIA
                        #71
                        BIOS
                        7wcn30ww.bin
                        330S_ARR_V06
                        thankyou work for me
                        • sebulica
                          Beginner
                          • Mar 2014
                          • 50
                          #72
                          Can someone help me with a good kbc dump for 330s arr v 06 ?
                          I made a dump with CH341A of the ene chip and bios...I think they got corrupted by an abrupt shutdown during bios update.I tried numerous bios files but all act the same: no image and restarting every 5-10 seconds with a short blink of power led.
                          • peste
                            • 13641
                            • ROMANIA
                            #73
                            post#2,5,25 should help you..if you used them, you might have another problem..
                            • sebulica
                              Beginner
                              • Mar 2014
                              • 50
                              #74
                              On post #5 is the dump for 9022...i have 9028.i have written it but the laptop does not start with that dump.I wrote multiple bios dump including from here,but i still suspect the ec might have a corrupted firmware on it.
                              but thanks for suggestions.
                              • peste
                                • 13641
                                • ROMANIA
                                #75
                                try and it's ...extracted from the update..
                                • sebulica
                                  Beginner
                                  • Mar 2014
                                  • 50
                                  #76
                                  The board acts like it does not recognize or accept the onboard ram.I found another board working cheap enough.thank you for your time
                                  • saiaapiz
                                    • Oct 2022
                                    • Badman
                                    #77
                                    Wow! I'm so excited to share that thanks to @junkfoodcafe and @peste, my corrupted bios is now fixed! And the best part is, I was able to use my old DMI information from the previous bios dump thanks to post #29. Huge thanks to these amazing people!
                                    • madjid911
                                      • 412
                                      • France
                                      #78
                                      Hi, Can you repair my bios please ?, it is corrupted, I changed the bios it works perfectly now but I would like to recover the data from my bios SN.... etc...
                                      • peste
                                        • 13641
                                        • ROMANIA
                                        #79
                                        read post #29
                                        • rotceh_dnih
                                          • Jun 2020
                                          • 43
                                          I tried to follow post #29 however @1EE000 there is no data just FF Likewise for @330250
                                          I downloaded the bios from post #2 but nothing I see here is lining up :/ .
                                          Please see attached picture, Surly I'm losing the plot and doing something silly just to many jobs going at once I think.
                                            Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:20 AM
                                            Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
