Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
  • aminemsaken
    AMINEMSAKEN
    • Oct 2023
    • 25
    • Tunisie
    #101
    my pc is rayen 3 without graphic
    I TRY #27 before i ask BUT NOT WORK
    • Christian0734
      • Nov 2020
      • 92
      • France
      #102
      LENOVO Ideapad 330S-15ARR
      MO: YDN0B882001W
      S/N: YD05B8QJ
      Motherboard: MV-6 94V-0
      Symptom: The PC starts, the fan runs, the lights are on. No display on the screen or HDMI port. Consumption: 1.5 A.
      Do you have a BIOS to test?
      Here is the backup of the BIOS.
      Thank you.
      • danito
        • Jun 2016
        • 1098
        #103
        try
          • 21948
          MO: YDN0B882001W
          S/N: YD05B8QJ
          Motherboard: MV-6 94V-0​
          Thread merged.Please make use of the forum search before posting to find related threads where you can post your request.You do not need to start a new thread every time.
          • Christian0734
            • Nov 2020
            • 92
            • France
            #105
            Originally posted by danito
            try
            Thank you very much, there is progress. The computer starts, and the screen displays this (see attached photo). What do you think?
            • Christian0734
              • Nov 2020
              • 92
              • France
              #106
              With the BIOS provided by danito , the 'LENOVO' logo appears and I can boot from my Ventoy SSD, as you can see in the photo. But as soon as I select an application and press Enter, the computer shuts down instantly. The same thing happens if I boot into Ubuntu: I can select the version, but as soon as the desktop is about to appear, the computer shuts down. It's not just the screen; the entire computer shuts down, with no power consumption. I've tried flashing it several times, but the result is the same. Does anyone have another BIOS to suggest?
              • Christian0734
                • Nov 2020
                • 92
                • France
                #107
                The PC is working, so I'll take this opportunity to remind everyone of a basic rule that I had forgotten! If the PC boots into the BIOS, make sure to load the default settings before proceeding further. I had forgotten to do this, and my PC was showing the symptoms I described in my previous post. Hopefully, this can help someone. Furthermore, for serial numbers and keys, I followed the procedure of a contributor in this thread using the HxD software, which is super easy. Thanks to all the contributors of this irreplaceable forum
                • Jose Manriquez
                  • Jun 2024
                  • Chile
                  #108
                  Dear community, I have the ideapad 330s-15arr model that turns on, does not give image in any way and the fan sounds a lot, after trying to install a nvme. Most likely the bios is corrupted. I bought a CH341 programmer, but when trying to make a backup of the original bios the software freezes without reading the Bios, try several programs and check the drivers, but I can not read the bios, is my CH341 in bad condition?
                  I am using windows 11.
                  greetings
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12333
                    #109
                    greetings
                    Which type of CH341A did you buy ?
                    What is the voltage of your bios chip ?
                    Which program do you use for CH341A ?
                    https://www.badcaps.net/forum/troubl...rces-and-tools
                    • Jose Manriquez
                      • Jun 2024
                      • Chile
                      #110
                      Hi, thanks for the interest, I checked the device and it comes with the CH341B chip, my bios is W25Q64FW 1.8v (I am using the voltage adapter). I updated the drivers and now the AsProgrammer 2.0.4 program does not freeze, but it is taking a long time to read the memory to make a backup (it will take about 5 hours). How normal is this, should the bios battery be connected or disconnected ?
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12333
                        #111
                        5 hours to read an 8MB chip is unusual. I don't use the CH341A so I'm not sure, but when reading/writing the chip, I will remove all power sources (including the CMOS battery) because at this time the power supply to the chip is pin 4 (Gnd) and pin 8 (VCC).
                        • fmarquis
                          • Jul 2024
                          • 5
                          • France
                          #112
                          My mother's laptop, a Lenovo Ideapad 330S-15ARR (model name : 81FB and factory ID : JVHFC1) is not starting correctly anymore.
                          If you press the power button, it powers up, you can hear the disk spining (at least an advantage of these old drives !), but nothing is displayed on the screen or on an external display.
                          Num Lock key is unresponsive too. I tried the Novo button (little hole on the right), same results
                          I can only shut it down with holding down the power button for a few seconds
                          So it looks like a corrupted BIOS like others on this thread...
                          I read all the posts, but some informations seems missing , so here are some questions please :
                          • I got the "template" BIOS from #27, and I understand that I need to Hex edit some values in this file, but how can i retrieve these values from the corrupted BIOS, which prevents me from starting the computer ?
                          • If I can't extract the old values from the corrupted BIOS, may I get them from the stickers or from another source ? If so, how ?
                          • If I get these value and set them in the template BIOS, I don't see how the put the new BIOS on the computer after... unless putting the BIN file on a USB stick can work on a dead computer ? Other solution seems to be linked to a "CH341A" item, which seems to be a chip writing tool. Every person that succesfully repaired their BIOS had this tool before ?
                          Can the bin file on a USB stick works ?
                          If I need a CH341A tool, do you have tips for choosing one (this one ? https://www.amazon.fr/TECNOIOT-CH341...dp/B07RKXSMKH/)
                          Thanks for your help, and sorry if my english is not good
                          Franck​
                          • peste
                            • 13641
                            • ROMANIA
                            #113
                            Franck​
                            you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
                            • fmarquis
                              • Jul 2024
                              • 5
                              • France
                              #114
                              So I need to :
                              * Buy a SPI programmer,
                              * Remove the bios chip from the motherboard, or use the clamp if possible
                              * Backup the original bios !
                              * Extract some data from it
                              * Copy the data on the template bios
                              * Write the new bios on the chip
                              * Hope it works
                              Thanks again
                              • jigger24
                                • Nov 2021
                                • 9
                                • cogoe antipolo city
                                #115
                                Originally posted by fire1234
                                Re: Lenovo IdeaPad 330S-15ARR
                                See if this works, it is a clean bios without any entries, if the next thing happens, you need to look for a bug on the pcb
                                SALAMAT master GOODS 101%
                                • AirbusPc
                                  • Aug 2024
                                  • 13
                                  • colombia
                                  #116
                                  Hello, I have an Ideapad 330S-15ARR (model: 81FB and factory ID: JVHFC1) it does not give video fans on... I try bios update usb but after fn + r for 5 minutes the charging light turns on and off but it does not give no beep , it does not load...... .bin file, how can I access it so that it can load, please help, thank you
                                    • 21948
                                    You will need to buy an SPI programmer or take the laptop to a repair shop
                                    https://www.badcaps.net/forum/troubl...96#post3304796
                                    https://www.badcaps.net/forum/troubl...post3305259​
                                    • AirbusPc
                                      • Aug 2024
                                      • 13
                                      • colombia
                                      #118
                                      thansk for your help
                                      https://articulo.mercadolibre.com.co...7-afdfe8b6d3aa
                                      that function to me case _?
                                      • AirbusPc
                                        • Aug 2024
                                        • 13
                                        • colombia
                                        #119
                                        I am very new to this I have 330s 15arr 81fb I bought ch341a ...with clamp ...I want to know if I need 1.8v adapter to flash BIOS winbond 1853 25Q64XXX or can I try without the Adapter thanks for the help and sorry for my bad English
                                        • kalilinux25
                                          • Mar 2018
                                          • 2089
                                          • ZAMBOANGA SIBUGAY
                                          #120
                                          25Q64XXX what is the complete full chip so I can see the datasheet and confirm if its a 3.3v or 1.8v chip
                                            Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:20 AM
                                            Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
