Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
  • Mumra
    • Aug 2025
    • North America
    #221
    Thank you for this great information, this thread helped me resurrect my wife's 330s-15arr
    Used bin file from Post #27 and used information from post #29 to transfer DMI data
    Purchased a CH341 with 1.8v adapter from Amazon selected the one that would be delivered the next day.
    Applications used NeoPrgramer and HxD
    Used CH341PAR Driver from wch-ic.com
    • vealiraza
      • Feb 2023
      • India
      #222
      Originally posted by mahmoodjavan
      Re: Lenovo IdeaPad 330S-15ARR - 330S_ARR_V06
      BIOS
      7wcn30ww.bin
      330S_ARR_V06
      100% working thank u sir
      • bob888
        #223
        Thank you for all the useful information in this long thread. Successfully revived a relative's 330S-15ARR. Only fan and Power Button light came on. CAPS LOCK did not respond to key presses prior to fix. Novo button did not solve problem. Screen remained blank.
        330S-15ARR
        Ryzen 5 2500u, UK model
        Model Name: 81FB
        MO: PF9XB8C01091
        MTM: 81FB002LUK
        Mfg date: 18/12/01
        S/N:
        Factory ID: JVHFC1
        I used the bin file from Post #27 and instructions from post #29 to transfer DMI data.
        I purchased a CH341 programmer with all the accessories including 1.8v adapter from Aliexpress for less than 6 UK Pounds. Delivered to UK in 6 days. The seller was Realpoy Module Wholesale, who had sold 5000+ fwiw.
        Applications used:
        NeoProgrammer v2.2.0.10 (from link in a onetransistor eu article I was reading)
        HxD editor
        CH341PAR.exe Driver from wch-ic.com
        I'm 90% certain the laptop was already running latest firmware ...38WW, updated through Windows Update (It shipped with ...30WW) many years ago. Lenovo Vantage is not installed. I didn't know how to block firmware updates using Device Manager until recently.
        Checking the windows update log, there was one update "Lenovo System - 1.2.0.11' installed very shortly before the laptop failed. There is a Pending 2025-08 Cumulative update.
        Googled:
        Lenovo System - 1.2.0.11 refers to a specific version of the Lenovo System Interface Foundation device driver. It's a system software component that provides a connection for Lenovo Vantage, a system management application, and other Lenovo software to access hardware information and manage system settings. This driver facilitates updates to drivers, BIOS, and other software for Lenovo ThinkPad and ThinkCentre systems
        • moscast
          • Oct 2023
          • 39
          • ITALY
          #224
          Hi everyone, can anyone fix this bios that's giving me a black screen?
          The maionboard is MV-6 94V-0 E89382 the CPU is ADM
          Notebook model: Lenovo ideapad 330S-15ARR
        • TDSAiud
          • May 2023
          • România
          #225
          Hello, can you help me with this bios file, it has no image. I rewrote another bios everything works ok but I can't identify the DIM information from the old bios.
          model name:81FB
          FACTORY: GXSC
          S/N: YD04QDW5
          MTM: 81FB005URM
          MO:YDN0B861601G
          • hoaca388
            Badcaps
            • Jan 2022
            • 12333
            #226
            model name:81FB
            FACTORY: GXSC
            S/N: YD04QDW5
            MTM: 81FB005URM
            MO:YDN0B861601G
            330S-15ARR Laptop (ideapad) - Type 81FB
            • TDSAiud
              • May 2023
              • România
              #227
              thanks but it doesn't work MTM is invalid / lenovo sn invalid /uuid number is invalid
                • 21948
                Try this bios. If you want to change any DMI use the U1 tool - https://www.badcaps.net/forum/troubl...24#post1622424
                • dacoty07
                  • Apr 2024
                  • coloombia
                  #229
                  I fixed exactly the same problem.
                  Oirginal is BIOS chip 25q64fw - it's 1.8V chip, You need to reprogramm original chip with 1.8V. It will not work on 25Q64FV 3.3V chip, it will spins and slow down fans.
                  BIOS from post #2 works!
                  CONFIRMADO, TAL CUAL PROGRAME A 3.3v Y QUEDO ASI, APAGA PRENDE, APAGA PRENDE, BAJE Y PROGRAME CON 1.8v Y SALIO FULL. GRACIAS POR EL DATO
                  CONFIRMED, EXACTLY AS I PROGRAMMED IT AT 3.3V AND IT STAYED LIKE THAT, TURN OFF, TURN OFF, TURN DOWN, AND PROGRAMMED IT AT 1.8V AND IT CAME OUT FULL. THANKS FOR THE INFORMATION
                  in English please...
                  • slivkamod
                    • Jul 2025
                    • ukraine
                    #230
                    Hello, everyone. I need help. I want to restore my laptop. I need the BIOS:
                    Lenovo IdeaPad
                    330S-15ARR
                    Type 81FB
                    s/n: PF1V2BW8
                    MTM: 81FB00HKUS
                    Thank you all in advance. Blessings!
                    • LBTT1121
                      • Nov 2024
                      • 1042
                      • Việt Nam
                      #231
                      Lenovo IdeaPad
                      330S-15ARR
                      Type 81FB
                      s/n: PF1V2BW8
                      MTM: 81FB00HKUS
                      post the contents of the bios chip even if it is corrupted..
                      • slivkamod
                        • Jul 2025
                        • ukraine
                        #232
                        Perhaps I am misunderstanding, but if you are referring to a dump of the old microchip, unfortunately, it does not exist. That is the main issue. Thank you.
                        • LBTT1121
                          • Nov 2024
                          • 1042
                          • Việt Nam
                          #233
                          try and feedback
                          • slivkamod
                            • Jul 2025
                            • ukraine
                            #234
                            try and feedback
                            Thank you so much!!!!!
                              Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 05:20 AM
                              Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                              Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 05:00 AM
                              Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                              This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
