L5x-B/S5x-B Bios
  • IDislikemakingLogins
    • Feb 2017
    • 38
    • moon
    L5x-B/S5x-B Bios
    I downloaded the bios from Toshiba, skt4v200.exe. i renamed to rar and extracted the file and found a file called blid200.bin. since the broken dump was 8mb and this was 8.6mb i compared the two and found they have junk in start and end of the file hex editor. since the bad dump had beginning and end matched I cut out the junk and programmed and seamed to have worked. from what i can tell it should work whit Satellite L5x-B/S5x-B (PSKT4x/T8x/TAx/TEx, PSPQ2x/Q4x/Q6x/Q8x) i used it on a s50-l. BIOS version 2.00
    http://support.toshiba.com/support/v...tentId=4007027
  • Chieftain
    • May 2016
    • 72
    • Greece
    Re: Toshiba L50-B Turns on but black screen
    Does this file worked for you? Did you change U17 ?
    • to5it0
      by to5it0
      10-24-2025, 01:35 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • maanee11
      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
      by maanee11
      Hello Everyone,
      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
      In the website, you can only see specs etc.
      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
      11-08-2025, 04:08 AM
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
