Dell latitude 7490 bios
    • 22097
    Originally posted by kondor12
    Dell 7490 I have a problem when booting for 40 seconds before the display appears. Can anyone help me to speed up booting?
    Cleaning the ME firmware should fix the slow boot - https://www.badcaps.net/forum/troubl...22#post1622422
    If you can`t do it yourself post your bios backup and the laptop service tag, and someone will help.
    • vamota
      • Sep 2021
      • 9
      Originally posted by vamota
      P.S. I should add that the reason I want to change the Service tag is that the laptop is enrolled to Microsoft Autopilot, and this is what I want to get rid of : I had assumed that changing the service tag was the best way to do this, but I have just discovered a separate active thread Dell Microsoft autopilot issue on this forum with screenshots outlining how to get rid of Autopilot by editing/invalidating the AUTOPILOT_MARKER sections using a hex Editor. I tried doing this on my bios, but wasn't clear on how exactly to do the invalidation step , so was not yet successful ..
      Bump
      Dell Latitude 7490 Autopilot issue : is anyone able to help remove Autopilot from the attached 7490 bios , please ?
      I'm able to install Windows on the laptop using the OOBE\bypassnro workaround, but I'd like to get the laptop into a state for the next user where it doesn't come up with this unknown company's logo whenever they reset the PC or re-install Windows ..
      Motherboard : DAZ40 , LA-F322P Rev.2.0(A01)
      Service Tag : 7XD4HR2
      thanks!
      • peste
        • Dec 2016
        • 13728
        • ROMANIA
        #263
        Bump
        thanks!
        try..
        • vamota
          • Sep 2021
          • 9
          Originally posted by peste
          try..
          Thanks peste, but unfortunately that still eventually comes up with the unknown company's logo during the Windows 11 fresh install ( on an empty SSD). However I think it progressed further through the Windows install than it did previously, as if the missing AUTOPILOT_MARKERs are not sufficient to get rid of Autopilot, and it falls back to using some additional method while it contacts Microsoft 365.
          Does it perhaps read some other data from the hardware config, and then use that to create the hardware hash used to identify the laptop on the Microsoft end ? I thought changing the service tag might be enough , so I tried temporarily flashing this laptop with the BIOS of another 7490 , but it still came up with the same company's logo, which I found surprising ! :~
          • Microm
            • Sep 2019
            • 29
            • Perú
            #265
            Hi i need to fix this bios file.
            Service Tag: 3B0KTQ2
            DELL LATITUDE 7490
            DAZ40 LA-F322P REV 1.0
              • 22097
              DELL LATITUDE 7490
              Can you explain what the problem is, no boot, black screen etc
              • Microm
                • Sep 2019
                • 29
                • Perú
                #267
                The laptop turns on and then shuts down. A common error on Dell laptops with a corrupted BIOS.
                • haiermobile
                  • Sep 2017
                  • 10
                  • pakistan
                  #268
                  DELL LA F322P REV 2.0
                  ONCE LAPTOP TURNS ON IT WORK GOOD, IF SHUTDOWN NERVER TURN ON EASLY, KEEP PRESSING BUTTON TURN ON SOME TIME
                  service tag 1QFG5S2
                  • haiermobile
                    • Sep 2017
                    • 10
                    • pakistan
                    #269
                    working bios la f322p 2.0 extracted from working laptop
                    • jkimani
                      • Apr 2020
                      • 19
                      • Kenya
                      #270
                      I have dell e7490
                      Service Tag: 8Y320N2
                      DAZ40 LA-F322P REV1.0(A00) that powers but has no display, pls any help will be appriciated. Thanks
                      below is my orginal file
                        SMDFlea commented
                        Editing a comment
                        Thread merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread.
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12413
                      #271
                      Originally posted by jkimani
                      I have dell e7490
                      Latitude 7490
                      • jkimani
                        • Apr 2020
                        • 19
                        • Kenya
                        #272
                        Originally posted by hoaca388
                        Latitude 7490
                        I have tried but still no display
                        • LBTT1121
                          • Nov 2024
                          • 1185
                          • Việt Nam
                          #273
                          I have dell e7490
                          try
                          • gizaha
                            by gizaha
                            02-13-2024, 07:18 AM
                          • Sathsul
                            Dell Latitude 5431 issues with dumping bios
                            by Sathsul
                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                            10-28-2025, 07:49 AM
                            DELL Latitude 7490 Notebook 7000 Specification for Upgrade or Repair
                            This specification for the DELL Latitude 7490 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7490 boardview and 7490 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7490...
                            09-06-2024, 12:36 PM
                            09-06-2024, 12:13 PM
