please help with Flashing MICOM
  • visitor1234
    • Jun 2019
    • india
    Hi I have Samsung N120 laptop. I have flashed wrong MICOM file and now the computer does not boot up. Can I flash MICOM chip on board. The detail are :
    Model Name : NP-N120, NT-N120
    Project name : WINCHESTER 2 / WINCHESTER2 / WINCHESTER-2 / WINCHESTER II
    Known PCB Codes: BA41-01056A BA41-01057A BA41-01058A
    Known PBA Names: BA92-05553A BA92-05510A BA92-05511A
    CPU : INTEL DIAMONDVILLE
    Chip Set : INTEL 945GSE + ICH7-M (82801GBM)
    Video : Internal GFX
    MICOM CHIP - H8S-2110B
    Please share N120 06E firmware also
    • 31304
    Re: please help with Flashing MICOM
    get yourself a datasheet for the hitachi/renaisys H8S-2110B
    see what it says.
    • visitor1234
      • Jun 2019
      • india
      I want to flash in circuit so I need help
        • 31304
        first you need to read up on it, some H8 have a lot of security.
        • STKR123
          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
          by STKR123
          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
          I wonder if re-flashing the BIOS might be of any use here.
          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
          11-03-2024, 06:58 AM
        • Yanleb
          LG 42LV5400-UB doesn't power up, Micom issue
          by Yanleb
          This repair is very challenging. I already made my way to the problem. Please read the complete post before commenting. I need the help from good gurus.
          The power button on the TV set is working, the same for the power button on the remote control. When activated the power LED changes from red to white and the power supply relay clicks. But no image appears, and no sound is heard.
          I already investigated the problem. the Micom chip on the EBR73110104/EBT61520408 main board is the issue. The Micom is IC602 that use the μPD78F0514 (UPD78F0514)...
          01-03-2022, 10:52 PM
        • learnmore
          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
          by learnmore
          Hello Community!
          CASE DETAILS
          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
          Tried inserting firmware on USB and left it in for a few hours, but no change
          03-03-2024, 09:49 AM
        • H34TO
          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
          by H34TO
          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
          06-17-2025, 07:17 AM
        • HTR-Informatique
          Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
          by HTR-Informatique
          YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
          I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
          On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
          I also changed the screen because the PC fell and the screen was broken.
          I changed the battery with a new and original battery.
          I also had corrosion/oxidation on the...
          02-09-2025, 06:51 AM
