I need a bios for hp la-e831p
  • mahmoud88
    • May 2017
    • 5
    • eygpt
    pleaze I need a bios dump for hp la-e831p
    thanx
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: I need a bios for hp la-e831p
    try..
    • mahmoud88
      • May 2017
      • 5
      • eygpt
      thank you but its not working , capslock flash 5time long .3 time short iam sure its bios error
      • adgaite
        • May 2017
        • 3
        • Argentina
        I had this firmware. It works in my computer, but it doesn't let me change any value. Every time I restart the laptop the bios reset the values.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          clean the me region and try.
          • srcncr
            • Feb 2017
            • turkey
            please help la-e831p rev 2.0 dump
            • eser
              • Aug 2020
              • thailand
              thx
              • Mcfalsi
                • Apr 2015
                • 193
                • Türkey
                dump need please help
                • peste
                  • Dec 2016
                  • 13924
                  • ROMANIA
                  post the full name and model of the laptop and the backup of the bios.
                  • salawayon
                    • Nov 2012
                    • 578
                    • philippines
                    Originally posted by peste
                    try..
                    It works on CRL51 LA-E831P REV: 1 with AMD A12-9720p system...thanks...
                    • srpr
                      • Oct 2019
                      • 12
                      • turkey
                      I tried on the same computer but it didn't work. Did you take any action?
                        • 22279
                        If you made a backup post it,along with your serial number and full laptop model number
                        • srpr
                          • Oct 2019
                          • 12
                          • turkey
                          "I had this firmware. It works in my computer, but it doesn't let me change any value. Every time I restart the laptop the bios reset the values." same problem
                          Can you help me?
                          • srpr
                            • Oct 2019
                            • 12
                            • turkey
                            Can you help me?
                            Model:2WE89EA
                            SN:CND73799FH
                            Cpu:A12-9720P
                            • thewill85
                              • Oct 2013
                              • 4
                              • Italia
                              hello, do you have solution?
                              • byhabit
                                Pozitif
                                • May 2016
                                • 7
                                • istanbul
                                working bios
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • mkdj
                                  by mkdj
                                  Dear all,
                                  10-19-2025, 04:41 AM
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • haitham sharabati
                                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                  by haitham sharabati
                                  Hello engineers 😀,
                                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                  🔧 Device Info:
                                  - Model: HP 15-da2007ne
                                  - Product Number: 8XF55EA#ABV
                                  - Serial Number: CND0338P0D
                                  - CPU: Intel Celeron N4000
                                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                  💀 Problem:😅
                                  - Device shows “Administrator Password”...
                                  08-07-2025, 04:54 AM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
