I need a bios for hp la-e831p
  • mahmoud88
    • May 2017
    • 5
    • eygpt
    pleaze I need a bios dump for hp la-e831p
    thanx
  • peste
    • 12959
    • ROMANIA
    Re: I need a bios for hp la-e831p
    try..
    • mahmoud88
      • May 2017
      • 5
      • eygpt
      thank you but its not working , capslock flash 5time long .3 time short iam sure its bios error
      • adgaite
        • May 2017
        • Argentina
        I had this firmware. It works in my computer, but it doesn't let me change any value. Every time I restart the laptop the bios reset the values.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          clean the me region and try.
          • srcncr
            • Feb 2017
            • turkey
            please help la-e831p rev 2.0 dump
            • eser
              • Aug 2020
              • thailand
              thx
              • Mcfalsi
                • Apr 2015
                • 192
                • Türkey
                dump need please help
                • peste
                  • 12959
                  • ROMANIA
                  post the full name and model of the laptop and the backup of the bios.
                  • salawayon
                    • Nov 2012
                    • 575
                    • philippines
                    Originally posted by peste
                    try..
                    It works on CRL51 LA-E831P REV: 1 with AMD A12-9720p system...thanks...
                    • srpr
                      • Oct 2019
                      • 12
                      • turkey
                      I tried on the same computer but it didn't work. Did you take any action?
                        • 21186
                        If you made a backup post it,along with your serial number and full laptop model number
                        • srpr
                          • Oct 2019
                          • 12
                          • turkey
                          "I had this firmware. It works in my computer, but it doesn't let me change any value. Every time I restart the laptop the bios reset the values." same problem
                          Can you help me?
                          • srpr
                            • Oct 2019
                            • 12
                            • turkey
                            Can you help me?
                            Model:2WE89EA
                            SN:CND73799FH
                            Cpu:A12-9720P
                            • thewill85
                              • Oct 2013
                              • Italia
                              hello, do you have solution?
                              • byhabit
                                Pozitif
                                • May 2016
                                • 7
                                • istanbul
                                working bios
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • haitham sharabati
                                  by haitham sharabati
                                  Hello engineers 😀,
                                  🔧 Device Info:
                                  - Model: HP 15-da2007ne
                                  - Product Number: 8XF55EA#ABV
                                  - Serial Number: CND0338P0D
                                  - CPU: Intel Celeron N4000
                                  💀 Problem:😅
                                  08-07-2025, 04:54 AM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • DynaxSC
                                  by DynaxSC
                                  11-17-2023, 10:56 AM
