Acer v5we2 Bios needed
  • mobajer
    • Feb 2017
    • 10
    • Lithuania
    Hello, i am looking for working bios for this ogic board: LA-9531P. (acer v5we2)
    thank you
  • peste
    • 13924
    • ROMANIA
    Re: Acer v5we2 Bios needed
    https://www.badcaps.net/forum/showthread.php?t=47096
    • mobajer
      • Feb 2017
      • 10
      • Lithuania
      Thank you peste for fast reply.
      i am quite new for bios flashing
      E1-572G_v5we2_la9531p.rar is that file compatible with my acer?
      as board model is exact same, but acer model is different?
      • peste
        • 13924
        • ROMANIA
        Make a copy of your bios and test the new bios, what model of Acer do you have?
        • mobajer
          • Feb 2017
          • 10
          • Lithuania
          Acer v5-561g-54208g1TMaik
          Z5WV2
          • peste
            • 13924
            • ROMANIA
            try...
            • as-it
              • Jan 2017
              • 5
              • iran
              Acer V5-561G V5WE2_LA-9531P_Rev 1A
              Gpu:216-085500
                • 22276
                Gpu:216-085500
                Is that a working dump or are you asking for help
                • Byronfool
                  • Nov 2022
                  • Italy
                  Hi everyone, I hope to find some saint here who can give me some support..
                  I'm working on this same mainboard.
                  I though I was facing a corrupted bios repair but now I'm not that sure anymore..
                  I tried to flash all version posted here with no luck.
                  Considering that I'm programming this chip QH64-104HIP as a EN25QH64 with a CH341a, is it possible that the chip is damaged even if the verify is ok? (I also can read the chip with no problems).
                  This is the situation:
                  Black screen at power up.
                  Only power, VGA and USB keyboard are connected at the moment.
                  Stand-by LED does not light up.
                  Blue LED light up after pressing the power button.
                  No LED and no button working on the USB Keyboard. The 5V power at USB is present.
                  5V and 3V are present at usual points.
                  No shorted capacitors (I've tested one by one)
                  No component gets unexpectedly hot after powering-on.
                  I've also removed the two coils and moved the resistor in order to convert to UMA so the GPU is not powered anymore..
                  Any suggest?
                  Thanks a lot in advance.
                  • peste
                    • 13924
                    • ROMANIA
                    Any suggest?
                    if you don't need bios move the discussion to the main forum, if you need bios, post S/N, full name and model, motherboard model, the contents of the bios chip even if it is corrupted..
                    etc.​
                    • Byronfool
                      • Nov 2022
                      • Italy
                      Thanks peste for answering.
                      Actually I'm still hoping this is a bios matter.. and still hoping to get a confirm about the chip.. does anybody faced a situation where even if the chip is damaged the verify is ok after programming it?
                      I wrote those additional info about this repair just to better picture the situation.
                      Here attached the dumped file and mainboard data.
                      Again thanks for any answer.
                        SMDFlea commented
                        Editing a comment
                        posts moved to a different thread.
