x300_Main_pcb Exper Main Bios dump
  • september11
    • Nov 2016
    • 17
    • istanbul
    Hi
    x300_Main_pcb Exper Main Bios dump Please
  • samet4434
    • Aug 2020
    • 15
    • Türkiye
    x300 MAIN PCB Bios Lazım (exper casper)
    I need EXPER L4B-01 Bios
    motherboard code same as casper
    x300_MAIN_PCB
    V1.05
    5000-0002-5105
    2012.0329.100
    NO ORIGINAL BIOS deleted
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • robgerr
      Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
      by robgerr
      Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
      Attach...
      11-17-2023, 09:52 AM
