HP omen 15-ax200ni bios
  • R34P3R
    • Nov 2015
    • 6
    • south africa
    Hello guys and gals,
    I am in need of a bios file for this unit. it turns on with no display or USB power then restarts after a minute or so. I have tried the bios file from HP but when I write it to a new I.C the caps light blinks 5 long and 3 short. I have tested the memory and it works fine so I am a bit stuck at the moment.
    on a side note, there are 2 8mb bin files from the hp site, I have tried both to no avail.
    Any help will be much appreciated.
    • 22279
    Re: HP omen 15-ax200ni bios
    Motherboard id, is it a DAG35AMB8E0 Rev: D or E
      • 22279
      There are 2 different bios for the 15-ax200ni ,BID08294 and BID0825F
      Both bios posted: https://www.badcaps.net/forum/showthread.php?p=883639
      • to5it0
        by to5it0
        10-24-2025, 01:35 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • maanee11
        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
        by maanee11
        Hello Everyone,
        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
        In the website, you can only see specs etc.
        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
        11-08-2025, 04:08 AM
      • m1ch43lzm
        by m1ch43lzm
        Hi everyone
        09-06-2025, 05:47 PM
      • Blur3195
        HP Omen 16-u0000sl. bios
        by Blur3195
        Hi, I have a problem with my HP Omen 16-u0000sl.
        I have a corrupted dump from which I extracted the DMI and inserted it into a stock BIOS. With the corrupted dump, the Caps Lock light blinks twice normally and twice quickly (BIOS corrupted). With the stock BIOS plus the DMI, the laptop starts a series of reboots but never initializes. I would be very grateful if someone could help me; I think maybe the DMI area is corrupted....
        08-22-2025, 11:24 AM
