Panasonic CF-54 Bios Password
try this one. Reinstall Windows from the beginning, it is possible that AutoPilot is already in win registry.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Bonsoir,
Je suis bloqué avec un mot de passe qui me verrouille l'accès au Bios. C'est un Panasonic CF-54D3961TF N° de série 7DTCA26181.
Ancien PC d'atelier, qui se trouve être obsolète et non repris par ma boite, m'a été gentiment offert. J'ai pu installer Windows 11 en passant par l'utilitaire Windows mais je ne peux faire aucun paramétrage de bios. Il est protégé par un mot de passe que personne ne peux me fournir.
Auriez vous une solution qui puisse me permettre de profité pleinement de ce PC.
Good evening,
I'm locked out of the BIOS by a password. It's a Panasonic CF-54D3961TF, serial number 7DTCA26181.
I was kindly given this old workshop PC, which happens to be obsolete and not returned by my company. I was able to install Windows 11 using the Windows utility, but I can't make any BIOS settings. It's protected by a password that no one can provide me with.
Do you have a solution that would allow me to fully enjoy this PC?
in English please...Comment
post the original contents of the bios chip..
The bios chip must be unsoldered from the board before writing or reading..
do not use the clip, you may have errors..if you do not have anything to unsolder it with,
solder wires between the programmer and the bios chip..
you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...l=ThisIsHowDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hey Guys need help with Panasonic CF54 to unlock bios
Model: CF-54DY024NG
S/N: 6DTSA61962
Attached FilesComment
try..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Hi, can somebody help me to unlock my bios password for Panasonic CF-54 MK1 (5TH Gen Intel cpu).
Ill attach Serials: CF-54A4442CM
6ETSA66550
-YAttached FilesComment
hi tryAttached FilesComment
Please remove the bios password.
Sn:8ctta10209
cf-54f507kmAttached FilesComment
Could I have some help unlocking the BIOS of my CF-54D3961TF, Serial No. 7DTCA26181?
I extracted the file from the MX 25L12873F BIOS chip, but when I read it, I only get FFFs. Is this normal? Can you solve my problem?
Attached is the BIN file.
here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
please remove the bios password
sno:9cttc22008
cf-54j2Attached FilesComment
Good evening, Peste, and thank you for the link.
Attached is the bios file.
If you could unlock the password for me, please.
Thanks in advance.
UnlockedAttached Files↵
https://www.badcaps.net/donateComment
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
- Loading...
