Alienware 18 (2013 edition) bios dump please
  • Safio
    • Jun 2017
    • 42
    hello
    im looking for an alienware 18 bios dump please
    thank you
    • 21324
    Re: Alienware 18 (2013 edition) bios dump please
    Post your serial number and bios backup if you have it .
    • Safio
      • Jun 2017
      • 42
      unfortunately i dont have the backup as im stuck on 8 beeps and no display issue but this is the tag number for it
      GK8KSY1
      motherboard VAS10 LA-9332P REV 1.0
      last working bios was VAS10A14
      is it possible to have the same dump of that version ?
      • Safio
        • Jun 2017
        • 42
        in case you need the original bios from dell website
          • 21324
          The VAS10A14 is only a 4MB bios update,not the full bios.I found a full bios that you can try, but the 8 beeps is an LCD error.Try the bios,if it doesn`t work reseat the LVDS cable on the motherboard and screen.Its also possible it could have a corrupt EDID, there`s a post over on notebookreview about the problem.
          http://forum.notebookreview.com/thre...panels.779449/
          http://forum.notebookreview.com/thre...781467/page-56
          • Safio
            • Jun 2017
            • 42
            Ok i will try and get back to you but do i have to flash the EC as well ? Or just the bios chip only ? If both can you help find the IC location on the mobo ?
              • 21324
              The bios is UH14 . Backup your old bios and verify it .Post your bios backup here, it may be repairable.
              • Safio
                • Jun 2017
                • 42
                ok i got that but still didnt get the answer for the EC do i have to flash it as well or just the bios only? the bios still on the mobo i have to pull it out andi will upload a backup sure
                • Safio
                  • Jun 2017
                  • 42
                  got the backup here can you check it out for me ?
                  i saw alot of forums talking about BIOS setup menu switch graphics settings from SG to PEG, would you be able to modify that in the bios and make it SG as default ?
                  thank you
                    • 21324
                    Try this new bios . If you want a modified version post your bios over at bios-mods.com .
                    • Safio
                      • Jun 2017
                      • 42
                      it was a faulty lcd and some peoples said you have to fix the eeprom i think in the lcd using a programmer, overall i tried another screen it work fine but was curious if there is a simple way to reprogram the screen ic or something ??
                      i do have a bios programmer so would that work ???
                        • 21324
                        Did you read post #5 ? The Alienware eeprom EDID dumps are on notebookreview. Yes you can reprogram the chip: https://www.badcaps.net/forum/showthread.php?p=881365
                        • caiqinlin
                          • Jul 2020
                          • China
                          Hello friend, I have an AW 18 r3 2013, it has a problem, every time I cold boot it, there will be completely black screen for 30 minutes, after that everything just fine, I learned that this is due to bios ME region corruption, and the only way to fix it is to rewrite the bios with a bios programmer. Thanks for your infomation let me know the chip is UH14.
                          I have a question, can I use this file you posted to rewrite my bios chip?
                            • 21324
                            yes .
                            • caiqinlin
                              • Jul 2020
                              • China
                              yes .
                              Thank you. Sorry what I forgot to is sya is I have updated the GPU to GTX970, and the bios file you posted look like has a 765m, will that be ok for my laptop?
                                • 21324
                                I don`t know,you may have to modify the vBios, do some research https://uk.alienwarearena.com/ucf/sh...de-to-gtx-970m
                                • alihomee
                                  • Dec 2012
                                  • 1577
                                  • malaysia
                                  its working perfectly
                                  • nissimezra
                                    AMMTS-SH Alienware Aurora Ryzen Edition R10 Bios dump
                                    by nissimezra
                                    Device: DESKTOP PC
                                    Brand: DELL
                                    Model: Alienware Aurora Ryzen Edition R10
                                    Service Tag: 3WVDTH3
                                    Express Service Code: 8517977463
                                    Board number: AMMTS-SH REV A00
                                    Request: BIOS dump
                                    Problem,: Black screen
                                    CPU Ryzen 7 5800
                                    No error code just black screen
                                    thank you...
                                    05-19-2025, 10:52 AM
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • drux
                                    Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                                    by drux
                                    I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                                    Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                                    These models have AMI/Aptio BIOS.
                                    Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                                    11-03-2024, 01:18 AM
                                  • Arc717
                                    How do I flash bios to an Alienware M16 R1 AMD edition?
                                    by Arc717
                                    I am trying to downgrade my bios on my Alienware so I can undervolt & overclock my CPU, and overclock my ram. I need to get to bios 1.2.2 for this. Dell doesn't allow downgrades, and their bios file is an exe compiled in c++, so I can't decompile it easily. I am wondering if I can flash the bios manually using a usb flasher. I would like to know if this is possible, and if so, where the bios chip would be. I know flashers are pretty cheap and the bios chip is 8-pin. There are two of these chips only when I open the back panel of the laptop. I'm not sure if there are any on the other side of...
                                    05-17-2024, 03:34 PM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
