Lenovo g50-45 bios
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Lenovo g50-45 bios
    MODEL:LENOVO G50-45
    TYPE:80E3
    PROCESSOR:AMD A4
    MB CODE:NM-A281 REV 1.0
    I need this bios. This is a amd cpu based machine and not intel, so remember that before uploading a bios.
    It shows $Kabini at hex address 24 4B 61 62 69 6E 69 whereas a intel cpu based dump will show $Mullins at hex 24 4D 75 6C 6C 69 6e 73 .
    I'm uploading my dump also. The problem is late display and sometimes even no display. I couldnt find the bios update at lenovo site. All updates are intel based.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Lenovo g50-45 bios
    MODEL:LENOVO G50-45
    TYPE:80E3
    PROCESSOR:AMD A4
    Try this.
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      Try this same bid.
      • Murtaza527
        • May 2018
        • 257
        • Malaysia
        this is tested ok bios
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Thanks for responding but it seems you have not read my post correctly. All these bios are likely to be good but all of them are showing $Mullins at hex 24 4D 75 6C 6C 69 6e 73 .
          I need $Kabini at hex address 24 4B 61 62 69 6E 69.
          I dont know if my assumption is correct or not. I even extracted CN45WW which is the latest version from lenovo site and made 8mb bios out of it but that also didnt worked(It too shows $mullins.
          NM-A281 rev 1.0 is amd cpu mb -so lenovo official update must be for amd only.
          I'm confused or am i heading in wrong direction. Btw, Original bios which i've attached gives display 8 out of 10 times.(the screen flickers for long time and then lenovo logo comes and thats my problem).
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            I doubt $mullins stands for non discrete and $kabini stands for Discrete versions. I'm not sure though.
              • 20311
              I think the bios has both VBios options,maybe a flag is set in an older bios or EC.It could also be a problem with the motherboard.In the NM-A281 r.0.4 schematic the only mention of Kabini is the BOM, Kabini@ APU part and RC28 Kabini@
              https://en.wikipedia.org/wiki/Socket_FT3
                • 20311
                2 more bios to try .
                • Wahaz
                  by Wahaz
                  10-30-2023, 08:42 PM
                • grimacelord
                  Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                  by grimacelord
                  Hello there.
                  I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                  History:
                  1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                  I searched for this error online and discovered...
                  03-15-2023, 03:29 PM
                • jendkkd jeje
                  Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
                  by jendkkd jeje
                  So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
                  I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
                  10-11-2024, 03:12 PM
                • mximiliandz
                  help bios lenovo ideapad s145-14iil type 81w6
                  by mximiliandz
                  Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
                  06-20-2025, 06:50 AM
                • 1g0r
                  Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                  by 1g0r
                  First, the data in brief:
                  Manufacturer: Lenovo
                  Model: ThinkPad L15 G3 21C3-0016GE
                  motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                  IC Bios 1: MX77L25650F
                  IC Bios 2​: MX25L25673G
                  EC Chip: NPCX997KAABX
                  So far I've been a silent reader, but now I need your help
                  I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                  I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                  The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                  01-18-2025, 02:39 AM
