HP 640 g1 smc file
  • Daudi83
    • Dec 2018
    • 66
    • Hungary
    HP 640 g1 smc file
    Hellow. Does anybody have an SMC.bin file to switch on the Manufacturer Programming mode on in my laptop ?Its start with missing serial, pruduct id numbers and wanna rewrite the values. Thank You
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: HP 640 g1 smc file
    Smc.bin its not a free other dmi sn,pn is possible to fix edit bios dump
    • Daudi83
      • Dec 2018
      • 66
      • Hungary
      Thank You for the quick reply Imranromi.What is Your suggestion, is there any way to switch on the MPM mode or just left the way to remove the bios chip and rewrite?
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Hmm yes you need tool bios programmer for read chip.
        • Daudi83
          • Dec 2018
          • 66
          • Hungary
          I tried to install the Bios Config utility and unlock it again but no luck
          Thanks for the Help
          • Daudi83
            • Dec 2018
            • 66
            • Hungary
            Hellow again, i tried the new bios for my laptop, after i got the machine is not committed state message. Can anybody just open for me the old bios file what i have? I just need just to fill the parameters with the HP Dmi tools program.
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              Machine is not committed state error in Me region area.If you have old/new bios dump post here i try to solve.
              • Daudi83
                • Dec 2018
                • 66
                • Hungary
                https://mega.nz/#!CohUmaQa!eI18JctKw...7l3_spBAvNVQT4
                • Daudi83
                  • Dec 2018
                  • 66
                  • Hungary
                  This is the old what was originally , and its works for me just forgot all the parameters after when the electricity went off...
                  • imranromi
                    • Jan 2015
                    • 1288
                    • Pakistan
                    This file no error right?Means machine is not comm......
                    • Daudi83
                      • Dec 2018
                      • 66
                      • Hungary
                      That what we started the discussion a week ago, i need to refill the parameters of the machine again,but the mpm state is locked...
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        Try this file add info file is my serial number or other info
                        2nd file is you add own serial number Use wndmifit tool
                        • Daudi83
                          • Dec 2018
                          • 66
                          • Hungary
                          • BBOYDU
                            • Jun 2021
                            • 5
                            • Brasil
                            after write information with unlocked mpm bios file, commit and lock, but after this this a message on top 'warning this machine is not in a committed state' how to fix?
                            • peste
                              • Dec 2016
                              • 12941
                              • ROMANIA
                              try this..
                              https://www.youtube.com/watch?v=9T57ktw8n3Y
                              • imranromi
                                • Jan 2015
                                • 1288
                                • Pakistan
                                Here fixed.
                                • BBOYDU
                                  • Jun 2021
                                  • 5
                                  • Brasil
                                  Here fixed.
                                  I flash this file but dont have mpm unlocked
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    You want what?mpm why want you unlocked.
                                    My file give any error?
                                    • BBOYDU
                                      • Jun 2021
                                      • 5
                                      • Brasil
                                      no your file is perfect, but I need to write my information, like serial, sku number, because of this I need mpm unlocked, how can I unlock mpm?
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        Where is your information.You have old bios post here i will replace you data
                                        • Forest79
                                          by Forest79
                                          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                          07-23-2023, 07:39 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • hazem3636
                                          need Bios Bin file Dell server 220
                                          by hazem3636
                                          hi everyone
                                          i need dump file for dell server r220
                                          i have download Flash BIOS executable file but i dont know how to conver it to Bin file
                                          i have check on youtube there is some programs are doing this method of creating Bin file from ExE file .
                                          if anyone has this method please need his supporting .
                                          all the best
                                          EXE file is attched and Original Bin file from the Bios Chip is attached also
                                          and dell website "https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=mrxv...
                                          11-05-2022, 06:20 AM
                                        • Sebastian Codrean
                                          BIOS file for ASUS F542UN laptop
                                          by Sebastian Codrean
                                          Hello to all of you! I need help with a BIOS file.
                                          The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                          So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                          02-20-2025, 10:25 AM
                                        • maanee11
                                          Help to get Lenovo BIOS bin file for Thinkpad T560
                                          by maanee11
                                          Hello Everyone,
                                          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                          05-15-2022, 11:59 AM
