Clean ME bios Dell N4010 DIS
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Clean ME bios Dell N4010 DIS
    N4010 cannot be converted to uma.
    • zamilal17
      • Sep 2023
      • painan
      My dell n4010 laptop has no switch, when i switch the sus_on signal is not present, i have done an ec change but the sus_on signal is still not present. I haven't tried to flash the bios, so i ask to please send me the bios file to solve the problem no switch in mylaptop
        • 22286
        • mrrubik
          Dell Optiplex 7010 micro bad BIOS flash?
          by mrrubik
          Hi folks,
          I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
          After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
          Steps I took:
          1. Read BIOS with CH341a, verified hash twice
          2. Patched
          12-23-2024, 04:11 PM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • YOUCEF4787
          Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
          by YOUCEF4787
          I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
          Initial Problem:
          The laptop was completely dead, no signs of life, no power LED.
          Action Taken:
          I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
          Current Situation & The Main Issue:
          The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
          09-21-2025, 12:19 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
