Iris BTM MB 14214-1 bios dump
  • hoaca388
    Badcaps
    • Jan 2022
    • 12441
    Originally posted by Duranitron
    thank you very much.. your bios works..HOw did you repair my bios?
    That is a new file.
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Originally posted by hoaca388
      That is a new file.
      ah ok. thank you very much for the help..
      Never stop LEARNING because life never stops TEACHING!
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
        by haitham sharabati
        Hello engineers 😀,
        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
        💀 Problem:😅
        - Device shows “Administrator Password”...
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
