Bios need HP elitebook 850 G1
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Good morning, I am looking for a bios for this laptop HP Elitebook 850 G1 product D8H45AV
    • 21519
    Re: Bios need HP elitebook 850 G1
    Can you post your bios backup .
    • ziggster
      • Feb 2019
      • 72
      • israel
      what is the m\b model ?
      meanwhile, try this:
      • Fabbrone
        • Jun 2015
        • 158
        • italy
        I have difficulty with my tl866 read the source of the two chips, I have to remove (chek-id) on the program minipro to be able to read them and I think the empty content. Both the bios and the ec chips.
        the laptop does not show signs of life no LED but there is voltage at the ends of the battery.
        attached the two sources
        A mainboard HP code is 730809-001
          • 21519
          There was a little bit of code in U366Old ,check your tl866 firmware and reseat in zif socket . Are you using a clip ? ,if so desolder them.
          • Fabbrone
            • Jun 2015
            • 158
            • italy
            Yes they are desolder, I did the upgrade but did not improve, I will buy the new version tl866 2 plus
            • Fabbrone
              • Jun 2015
              • 158
              • italy
              ok finally the new TL866 2 plus arrived and read the source without problems.
              I attach the source. If anyone has the original thank you
                • 21519
                Try these. The first bios old1_ME CLEAN is your bios with clean ME.The 2nd has the latest update merged,but you will lose DMI info,you may have to use nbdmifit/BCU to add the DMI info.
                • Fabbrone
                  • Jun 2015
                  • 158
                  • italy
                  Update, with the last bios now the laptop only turns on the white led for 10 seconds then turns off and turns on the orange one for a moment. then the orange-white LED turns on alternately 2 times. The fan does not start and neither does the video
                    • 21519
                    Try this new one .
                    • Fabbrone
                      • Jun 2015
                      • 158
                      • italy
                      always the same, probably the problem is somewhere else
                        • 21519
                        Can you post your U366 dump .Is the motherboard part number one of these: 6050A2560201-MB-A03
                        6050A2559101-MB-A03
                        • Fabbrone
                          • Jun 2015
                          • 158
                          • italy
                          Yes it is
                            • 21519
                            Try this new EC ,if it doesn`t work i think the problem must be somewhere else .
                            • Fabbrone
                              • Jun 2015
                              • 158
                              • italy
                              Thank you very much for your support and help but continue to make the usual LED signals. Probably the problem will be on the chipset or video. I have always had problems of this type with elitebook series laptops sometimes they do not turn on and abnormal flashes of the LEDs
                              • ofiden
                                • Jan 2020
                                • 3
                                • Uruguay
                                Thank yo very much
                                • Usedcom
                                  Usedcom
                                  • Dec 2015
                                  • 24
                                  • Polska
                                  old is ok.. thanks
                                  • abbassink
                                    • Aug 2015
                                    • 83
                                    • iran
                                    old bios is ok thanks
                                    • pronto
                                      • Mar 2019
                                      • 120
                                      • morocco
                                      working bin
                                      • perzyk23
                                        • Mar 2017
                                        • 31
                                        • Poland
                                        Hello!
                                        I have problem with Hp 850 G1 - The laptop is my wife's.
                                        When she starts the computer, the following message is displayed as in the photo.
                                        I am also attaching the bios files downloaded from this laptop.
                                        Configuration:
                                        I7-4600u / 16 MB RAM/ 256 SSD/ Intel HD + AMD RADEON HD8500M/ FHD
                                        BIOS ver: 01.49
                                        Does anyone know how to fix this? Please help.
                                        • Wutru
                                          HP Elitebook 820 G4 BIOS repair assistance required
                                          by Wutru
                                          Hi guys,
                                          If someone would be able to provide some expertise, I'd be very grateful.
                                          BIOS Corruption - Cause
                                          So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                          After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                          09-06-2025, 10:32 AM
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • Guest
                                          Elitebook 850 G5 BIOS bricked
                                          by Guest
                                          I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                          I assume the BIOS update failed, so I searched for the BIOS chip.
                                          I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                          However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                          Can the corrupted...
                                          03-24-2025, 01:21 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
