Panasonic CF-33 Bios bin svp
  • hoaca388
    Badcaps
    • Jan 2022
    • 12330
    Originally posted by Israelvzla
    After writing file screen become dark, is there anything else to do? If I connect hdmi a can see windows, it takes more time to boot than before
    Check the hardware, see if the display cable is plugged in tightly.
    • Israelvzla
      • Nov 2024
      • 13
      • Venezuela
      Checked and it's ok, I didn't disassembled completely to do the process, remove the camera cover, bios is there, soldered cables, with batterys removed of course, and did the backup and writing, if I put my phone flash light to the screen I can see image, with no backlight, checked hardware close to bios and there were no mistakes.
      • hoaca388
        Badcaps
        • Jan 2022
        • 12330
        You have hardware failure.
        • Israelvzla
          • Nov 2024
          • 13
          • Venezuela
          Going to write back backup and check, everything was working perfectly before, just bios password, now I can see bios settings but with dark screen, also checked other posts and there is another user who faced the same situation and solved the problem writing back backup and unlocking it again
          • hoaca388
            Badcaps
            • Jan 2022
            • 12330
            The clear ME file solves the slow boot problem.
            • Israelvzla
              • Nov 2024
              • 13
              • Venezuela
              #26
              Ok, going to do both tests maybe tomorrow, it's already midnight here, I don't think it's a hardware problem as I've used microscope and good soldering that I do every day, but anyways going to re-check everything.
              • Israelvzla
                • Nov 2024
                • 13
                • Venezuela
                #27
                After writing this dump, Toughbook won't boot on batterys, just with the power cord connected, and still dark screen, one thing to note is that I've updated bios and ME firmware sime days ago, could that anything to do with the problen I'm facing?
                • Israelvzla
                  • Nov 2024
                  • 13
                  • Venezuela
                  #28
                  Ok, I would probably be the most idiot person, but I must say it, it wasn't hardware fialure, it wasn't Bios file, in fact both files provided works, Toughbook wasn't booting on batteries and no backlight due I was testing it with the battery lid cover removed, and there is a metal piece on the lid for a sensor or maybe a reed switch to sense that metal piece, after I installed the lid, Toughbook booted perfectly on batteries and with backlight, thank you so much, I've learned something new at this time.
                  • akcn
                    • Jan 2020
                    • 17
                    • jp
                    #29
                    need CF-33 intel 12th bios the bios model is CF-VZSU1A, attached the locked bios.
                    AMITSESetup doesn't work on this model.
                    • shiyab
                      • Sep 2023
                      • 1609
                      • india
                      #30
                      hi try
                        • 21932
                        Thread merged. Type the laptop serial number, full name and model, motherboard model, etc.
                        read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                        • cachetop
                          • Jun 2014
                          • 7
                          • hungary
                          #32
                          Hi, please remove bios password.
                          CF-VEK33 CF-VEK201TG sn: 8JTCA39630
                          CF-33
                          • shiyab
                            • Sep 2023
                            • 1609
                            • india
                            #33
                            CF-33
                            hi try
                            • cachetop
                              • Jun 2014
                              • 7
                              • hungary
                              #34
                              Thank You!
                              • AquaMan Ua
                                Problem with PANASONIC CF53 laptop after changing BIOS settings
                                by AquaMan Ua
                                Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                                05-17-2025, 09:40 AM
                              • aa10aa10
                                Panasonic Toughbook CF-33 mk1 BIOS repair
                                by aa10aa10
                                Good day,
                                I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                                I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                                01-21-2025, 06:13 AM
                              • macabook
                                by macabook
                                🧩 Initial Issue
                                07-24-2025, 02:17 PM
                              • pirati
                                by pirati
                                10-27-2025, 04:20 PM
                                by Vesko356
                                08-11-2023, 03:27 AM
