Hp bdl51 la-d713p bios dump
  • reset1986
    • Dec 2014
    • 308
    • italia
    hi guys, i'm looking for bios for hp
    motherboard bdl51 la-d713p, amd a10
    I think this is corrupt, do not recover the bios with win + b, do you have a dump?
    • 21692
    Re: Hp bdl51 la-d713p bios dump
    https://ftp.hp.com/pub/softpaq/sp935...00/sp93520.exe
    Run the exe ,select Copy and save the bios .
    • reset1986
      • Dec 2014
      • 308
      • italia
      Run the exe ,select Copy and save the full bios .
      Thanks, working
      • mousavi
        • Nov 2016
        • 10
        • iran
        • ata.imran
          • Sep 2017
          • 20
          • pakistan
          Need EC ....
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            Originally posted by ata.imran
            Need EC ....
            ec file
            • ata.imran
              • Sep 2017
              • 20
              • pakistan
              Ene is not working plz give me a more files thanx
              • Mohammad Osama
                • Nov 2019
                • pakistan
                i need la-d713p ec file
                • peste
                  • 13451
                  • ROMANIA
                  have you read item # 6?
                    • 21692
                    The HP bios update for laptops with the la-d713p motherboard has 4 different BID`s 081F5,081F7,081F9 and 082F6 .Do you know what your bios i.d. is ? ,open your bios backup with a hex editor and search for $BID ,or post your bios backup here.The file posted by @Claudiomfa is the EC for 081F5 and 082F6 ,i`m not sure if it uses the same EC for the other 2 BID`s it could be different.
                    • ata.imran
                      • Sep 2017
                      • 20
                      • pakistan
                      my bios BID
                      081F9
                      • farrukh
                        • Apr 2019
                        • Pakistan
                        I need la-d713p ec file
                        My bios BID
                        081F9
                          • 21692
                          my bios BID
                          081F9
                          My bios BID
                          081F9
                          Post your bios backups here.
                            • 21692
                            I managed to extract the other 2 EC`s and they are different to the others.
                            here you go .
                            • ata.imran
                              • Sep 2017
                              • 20
                              • pakistan
                              Thanks alot..
                              100% working...
                              Display ok...
                              081F9
                              • mithat tatas
                                • Mar 2017
                                • türkiye
                                %100 çalışan
                                • mithat tatas
                                  • Mar 2017
                                  • türkiye
                                  • dahnking
                                    • Apr 2018
                                    • 262
                                    • kenya
                                    Originally posted by mithat tatas
                                    Confirmed and tested
                                    WORKING 100%
                                    Thank you
                                    • Hido_
                                      • Oct 2020
                                      • Türkiye
                                      thanks working
                                      • Stil86
                                        • Jun 2013
                                        • 16
                                        • Italy
                                        I have this motherboard with bios eprom damaged, if I take a backup, data are unreadable so I don't know what is my BID. How can I solve ?
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
