Hp bdl51 la-d713p bios dump
  • reset1986
    • 308
    • italia
    hi guys, i'm looking for bios for hp
    motherboard bdl51 la-d713p, amd a10
    I think this is corrupt, do not recover the bios with win + b, do you have a dump?
    • 20898
    Re: Hp bdl51 la-d713p bios dump
    https://ftp.hp.com/pub/softpaq/sp935...00/sp93520.exe
    Run the exe ,select Copy and save the bios .
    • reset1986
      • 308
      • italia
      Run the exe ,select Copy and save the full bios .
      Thanks, working
      • mousavi
        • Nov 2016
        • 10
        • iran
        • ata.imran
          • Sep 2017
          • 20
          • pakistan
          Need EC ....
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            Originally posted by ata.imran
            Need EC ....
            ec file
            • ata.imran
              • Sep 2017
              • 20
              • pakistan
              Ene is not working plz give me a more files thanx
              • Mohammad Osama
                • Nov 2019
                • pakistan
                i need la-d713p ec file
                • peste
                  • Dec 2016
                  • 12806
                  • ROMANIA
                  have you read item # 6?
                    • 20898
                    The HP bios update for laptops with the la-d713p motherboard has 4 different BID`s 081F5,081F7,081F9 and 082F6 .Do you know what your bios i.d. is ? ,open your bios backup with a hex editor and search for $BID ,or post your bios backup here.The file posted by @Claudiomfa is the EC for 081F5 and 082F6 ,i`m not sure if it uses the same EC for the other 2 BID`s it could be different.
                    • ata.imran
                      • Sep 2017
                      • 20
                      • pakistan
                      my bios BID
                      081F9
                      • farrukh
                        • Apr 2019
                        • Pakistan
                        I need la-d713p ec file
                        My bios BID
                        081F9
                          • 20898
                          my bios BID
                          081F9
                          My bios BID
                          081F9
                          Post your bios backups here.
                            • 20898
                            I managed to extract the other 2 EC`s and they are different to the others.
                            here you go .
                            • ata.imran
                              • Sep 2017
                              • 20
                              • pakistan
                              Thanks alot..
                              100% working...
                              Display ok...
                              081F9
                              • mithat tatas
                                • Mar 2017
                                • 3
                                • türkiye
                                %100 çalışan
                                • mithat tatas
                                  • Mar 2017
                                  • 3
                                  • türkiye
                                  • dahnking
                                    • Apr 2018
                                    • 257
                                    • kenya
                                    Originally posted by mithat tatas
                                    Confirmed and tested
                                    WORKING 100%
                                    Thank you
                                    • Hido_
                                      • Oct 2020
                                      • Türkiye
                                      thanks working
                                      • Stil86
                                        • Jun 2013
                                        • 15
                                        • Italy
                                        I have this motherboard with bios eprom damaged, if I take a backup, data are unreadable so I don't know what is my BID. How can I solve ?
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Yesterday, 05:12 AM
                                        • TripTop
                                          Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                                          by TripTop
                                          Hi
                                          i have dell latitude E7270 with following symptoms:
                                          - takes long time to restart.
                                          - sometimes powers on and then off
                                          - sometimes while working it just dies,
                                          From googling online bios clean could possible resolve this?
                                          i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                                          As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                                          I reinstall...
                                          09-09-2024, 02:05 PM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
