Need Bios HP 470-G4
  • Richi_el
    • Nov 2013
    • 95
    • Koln
    Need Bios HP 470-G4
    iam looking for a bios bin file for HP 470-G4
    Thnx for support ....
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Need Bios HP 470-G4
    Post here old bios i build new
    • Richi_el
      • Nov 2013
      • 95
      • Koln
      should i read the old bios with programmer and post it here ?
      • mahmoodjavan
        Banned
        • Mar 2018
        • 584
        • iran
        plz test
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          Yes right i build new if bios problem i sure your problem solve.
          • Richi_el
            • Nov 2013
            • 95
            • Koln
            Hello , thanks for your support i will test it and inform u about
            for first thank you & hodafez
            • Richi_el
              • Nov 2013
              • 95
              • Koln
              i will read the old bios and upload it, thnx for first ...
              • Richi_el
                • Nov 2013
                • 95
                • Koln
                Hello please can u repair this bios file, it is the org. bios wich is faulty ive read from book.
                HP 450 G4 bios is working but not correctly with this board
                • Richi_el
                  • Nov 2013
                  • 95
                  • Koln
                  [QUOTE=Richi_el;882317]Hello please can u repair this bios file, it is the org. bios wich is faulty ive read from book.
                  • imranromi
                    • Jan 2015
                    • 1288
                    • Pakistan
                    Try this.
                    • Richi_el
                      • Nov 2013
                      • 95
                      • Koln
                      Try this.
                      Hello i ve tested the file but it doesnt work no reaction on book
                      the book started with the bios File
                      Type: rar 450 g4 DA0X83MB6H0 REV H.rar
                      from mahmoodjavan
                      but the problem is that some features in this bios file are missing for the 470 g4
                      please can u check the file again ?
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        from mahmoodjavan
                        Where is original bios bad file post here i try to fix.
                        • Richi_el
                          • Nov 2013
                          • 95
                          • Koln
                          This one is wich ive read (bad file)
                          • imranromi
                            • Jan 2015
                            • 1288
                            • Pakistan
                            Try this both file.
                            • Richi_el
                              • Nov 2013
                              • 95
                              • Koln
                              Try this both file.
                              Thank you worked fine
                              • jonoldsdev
                                • Sep 2020
                                • 26
                                Are those two file personal to his system or would I be able to flash them also?
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
                                • m1ch43lzm
                                  Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                  by m1ch43lzm
                                  Hi everyone
                                  I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                  Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                  Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                  There's also an extra OTP Secu.R...
                                  09-06-2025, 05:47 PM
                                • Forest79
                                  by Forest79
                                  However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                                  07-23-2023, 07:39 AM
                                • maanee11
                                  Help to get Lenovo BIOS bin file for Thinkpad T560
                                  by maanee11
                                  Hello Everyone,
                                  I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
                                  https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
                                  In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
                                  05-15-2022, 11:59 AM
                                • Sebastian Codrean
                                  BIOS file for ASUS F542UN laptop
                                  by Sebastian Codrean
                                  Hello to all of you! I need help with a BIOS file.
                                  The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                  So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                  02-20-2025, 10:25 AM
