HP 14-BS507TX bios needed
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Re: HP 14-BS507TX bios needed
    thanks for the response SMDFLEA, but I already tried replaced the bios chip and programmed with the above file from romy because my board is the same board id and had radeon graphics same as above.tried both reflaced EC with ON/OFF file using SVOD 3, But same issue CAPS LOCK blinks 5times then 3fast blinks. I dont have scope.
      • 22279
      Post your original bios backup .Did you clean the ME region form romy`s bios dump ? .You may need a different bios BID ,there are 4 different ones 084D6,0831E,08320,08322
      • String2016
        • Nov 2015
        • 2242
        • philippines
        Here is my original dump can someone clean the me region this i have same problem above
        • String2016
          • Nov 2015
          • 2242
          • philippines
          @smdflea my original back up bios is broken because of the chip cannot read, that is why i flashed with the above files the one with romy's file because i checked the board id and specs its the same as mine.could you clean the me region of the above romy's bios, Ill try to flash with clean me.already done flash the EC with ON/OFF file
            • 22279
            EDITED PLEASE READ FIRST.
            All these posted bios cover the HP 14-BS range, from Braswell / KabyLake / ApolloLake
            084D6 is not the full bios,just part of a bios update ,so i havn`t posted that one. 084D6 = GEMINI LAKE
            0831E full bios (1 bios chip) 0831E = KABY LAKE U (CSE ME 11)
            08320 full bios (1 bios chip) 08320 = BRASWELL (TXE 2)
            08322 Not full bios,Descriptor + ME/TXE area (2 X bios chip) 08322 = APOLLO LAKE (TXE 3)
            EDIT: Added EC .
            • String2016
              • Nov 2015
              • 2242
              • philippines
              #26
              thank you i will try your uploaded bios and feedback soon.
                • 22279
                I edited my post above with some more info. If you have the kaby lake cpu flash 0831EF44 bios and the 0831EF44 EC .
                • String2016
                  • Nov 2015
                  • 2242
                  • philippines
                  #28
                  @smdflea I tried again flash both main and EC with you file still the same issue 5blinks and 3fast blinks.please help on this
                  • on/off
                    • Oct 2016
                    • 333
                    • Indonesia
                    #29
                    Maybe not match with original board. since your original broken (BTW, what code your bios IC? my ezp2010 failed when detect IC if MX IC 8mb 1.8V, maybe you face same issue, cannot read if it MX IC aka macronic)
                    Find out your code in bottom case near S/N and product code
                    REV: xxxx (xxxx it your code, then choose that match code by SMDFlea' file upload it)
                    in example see pic attahement: hp 240
                    Rev: 1854, mean the bios that match is 08154
                    also if want to try as last attempt, use my backup dump for hp14-bs005tx
                    • String2016
                      • Nov 2015
                      • 2242
                      • philippines
                      #30
                      the original bios chip has MX64 it is 3.3v and i replaced with Winbond q64fv chip.there is no REV: written on the board only SN/5CD8304YMY
                        • 22279
                        Do you have voltage at pin 8 of the bios.Test the resistors R101 to 109 and on the GPIO Pull UP
                        • String2016
                          • Nov 2015
                          • 2242
                          • philippines
                          #32
                          when i plugged the charger no voltage on PIN8 of the bios chip. I cannot find the resistors located
                          • on/off
                            • Oct 2016
                            • 333
                            • Indonesia
                            #33
                            Follow post#12, you got schematic + BV
                            • String2016
                              • Nov 2015
                              • 2242
                              • philippines
                              #34
                              thanks i have attached a image where 4 resistor connected to bios chip pins and show 0v
                                • 22279
                                Trace pin 8 +3VSPI on the boardview,there are 2 caps and 2 resistors on the other side of the board,test all those.R101 goes to +3V_DEEP_SUS .Check U4,+3VS5,PU10. Good luck with it .
                                • aymantv2020
                                  • Mar 2019
                                  • egypt
                                  #36
                                  :صخرة:good job
                                  • Vicksssgaber
                                    • May 2018
                                    • 8
                                    • Singapore
                                    #37
                                    Need schematic for this mainboard plz. Or boardview. Thankyou
                                      • 22279
                                      https://www.badcaps.net/forum/showthread.php?p=880341
                                      You should ask for schematics in the Schematic Requests sub-forum, and use the forum search.
                                      • giya
                                        • Apr 2020
                                        • 52
                                        • indonesia
                                        #39
                                        good luck
                                        THANKS, GOOD FOR ME
