Lenovo V370 bios dump
  • tomodachi
    • Apr 2012
    • 602
    • Turkey
    Lenovo V370 BIOS dump needed
    Motherboard code,
    Wistron
    LA37 MB
    10252-2
  • Andrew_R
    Banned
    • Jun 2018
    • 91
    • Poland
    Re: Lenovo V370 bios dump
    Post your dump.
    • tomodachi
      • Apr 2012
      • 602
      • Turkey
      will post tomorrow, mine working but have password, thanks
      • tomodachi
        • Apr 2012
        • 602
        • Turkey
        Originally posted by Andrew_R
        Post your dump.
        Here it is
        • Andrew_R
          Banned
          • Jun 2018
          • 91
          • Poland
          Originally posted by tomodachi
          Here it is
          Try this and post results.
          • tomodachi
            • Apr 2012
            • 602
            • Turkey
            Password still exist
            • Andrew_R
              Banned
              • Jun 2018
              • 91
              • Poland
              Ok, try this :
              • tomodachi
                • Apr 2012
                • 602
                • Turkey
                Ok, try this :
                Thank you very much, it works without password and boots fine
                I hope this dump works for people who need it later.
                • Joluvillas
                  Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                  by Joluvillas
                  Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                  06-18-2024, 10:35 PM
                • AHmad_Salal
                  Need BIOS Dump/ROM for Lenovo Thinkstation p500
                  by AHmad_Salal
                  Hello all,
                  I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                  11-28-2023, 05:28 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • TacticalFahrrad
                  [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                  by TacticalFahrrad
                  I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                  06-30-2025, 04:09 AM
                • hirens
                  Lenovo ideapad 3 14IGL05 bios dump needed
                  by hirens
                  model: 81wh
                  sn: pf36ta6h
                  board no: nm-c961 gs453/gs553
                  hey guys above is my laptop info
                  it only blinks the power button kindly help me with a working dump
                  old dump attached...
                  07-21-2023, 04:48 AM
