Lifebook S752 bios dump
  • wwenigma
    • Apr 2015
    • 6
    • Hungary
    Anyone has an S752 1.x BIOS+EC dump please? Official bios update went wrong...but i have a programmer.
    Thank you.
    • 22275
    Re: Lifebook S752 bios dump
    https://www.badcaps.net/forum/showth...highlight=S752
    • wwenigma
      • Apr 2015
      • 6
      • Hungary
      Thanks but i think i tried that, 2.x bios. No crossflash possible, it boot but cooler speed go to maximum rpm slowly and after 10 minutes , the notebook turn off suddenly.
        • 22275
        What is your full model number and serial .
        • wwenigma
          • Apr 2015
          • 6
          • Hungary
          DSCU563365
          CP562661-Z3 mainboard maybe, i cannot disassembled fully, only removed backplate to access eeproms.
          • wwenigma
            • Apr 2015
            • 6
            • Hungary
            Okay, so problem solved after risk some $.
            Crossflash is OK IF you do it manually...CPU cooler max speed and turn off was an ME problem, wrong EC firmware. Thast called "ME recovery mode". Solved by flashing clear ME EC image from a pay site.
            I dont know i allowed to share that file here?
              • 22275
              Yes you can share the file here,it may help others. The problem with fujitsu bios updates is they don`t usually have a full bios,just an update,and extracting some fujitsu bios is a problem, so dumps are needed to merge the bios updates , or to clean the ME . I found 2 dumps last night for the bios and EC but didn`t have time to clear the ME and post them here.
              • wwenigma
                • Apr 2015
                • 6
                • Hungary
                Thanks for trying help me anyway.
                Here is the image what i used to revive my notebook.
                Last edited by Vesko356; 07-03-2023, 01:44 PM. Reason: External url removed. Attached bios at the link to the post.
                • TacticalFahrrad
                  [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                  by TacticalFahrrad
                  I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                  06-30-2025, 04:09 AM
                • MohammedBathabet
                  Request BIOS dump for Fujitsu LIFEBOOK AH47/J (DAFH6BMB6A0)
                  by MohammedBathabet
                  I need a BIOS dump file for my Fujitsu LIFEBOOK AH47/J laptop.
                  Motherboard model: DAFH6BMB6A0
                  The system BIOS got corrupted and now the laptop powers on but does not boot.
                  I already tried the official Fujitsu support site, but the downloadable BIOS is only in .exe format and does not contain the raw .bin file needed for programming the BIOS chip directly with a programmer (CH341A).
                  If anyone has a working BIOS dump (.bin) for this model, please share it.
                  Thanks in advance!...
                  09-24-2025, 05:59 AM
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
