Hp Stream 14-cb***** DA0P9KMB6C1 bios
  • kimrocco
    • Jan 2014
    • 56
    • F2
    hello guys
    Does anyone have dump bios for Hp stream 14
    board number / DA0P9KMB6C1 Rev C
    Thank you
  • camachosoft
    • ecuador
    Re: Hp Stream 14-cb113wm Need dump bios
    i nee this bios dump too
    • alas3376
      • Nov 2011
      • 382
      • BENIN
      Try this
      • david.ercoli
        • Mar 2019
        • 5
        • argentina
        Hi guys,
        I burn the BIOS with this file, and now the laptop give me the following CAPS-LOCK blinks code:
        5 blinks long, then 3 blinks short,
        Do you know what means that code?
        THanks!
          • 20977
          The ME region is corrupt,the bios isn`t good. Post your original bios backup if you made one .
          • ghostlp.ls
            • Jul 2022
            • 8
            • portugal
            Good evening, I have an hp 14-cb101np with mb DA0P9KMB6C1 REV C that I leave here as a backup of my file, it turns on and after a few seconds it turns off... I tried with the file above it turns on and it no longer turns off and it even heats up the processor , but not the image.
            Will you be able to help me?
            I await response
            thanks​
            • Vesko356
              Vesko356 commented
              Editing a comment
              Read the rules before posting
              You MUST:
              • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
          • ghostlp.ls
            • Jul 2022
            • 8
            • portugal
            Good afternoon, unfortunately I don't have all the information, because the client already brought me the laptop disassembled, but I was able to see some information in the backup of the source file, I leave it here below, thanks for alerting me.
            5CD01955W8
            7DK77EA#AB9
            PHMGE018JDO1VZ
            HP Stream
            19H2
            PHMGE018JDO1VZ
            5CD01955W88591D5
            HP Stream Laptop 14-cb1XX
            DA0P9KMB6C1 REV C
            I think I'm fine now, I'm waiting for your help,
            thank you very much​
            • Vesko356
              Vesko356 commented
              Editing a comment
              This is an English language forum, post in English only please!
          • hoaca388
            Badcaps
            • Jan 2022
            • 11788
            5CD01955W8
            7DK77EA#AB9
            PHMGE018JDO1VZ
            HP Stream
            19H2
            PHMGE018JDO1VZ
            5CD01955W88591D5
            DA0P9KMB6C1 REV C
            HP Stream 14-cb101np Laptop PC
            • ghostlp.ls
              • Jul 2022
              • 8
              • portugal
              Good afternoon​, with this file the laptop makes 3 long blinks and 2 short blinks in caps/lock and does nothing else
              From what I researched in the HP error table it says it is BIOS.
              I await response
              thanks
              • hoaca388
                Badcaps
                • Jan 2022
                • 11788
                I await response
                thanks
                Change bios chip anh retry.
                • pc one
                  • Sep 2024
                  • 3
                  • morocco
                  hey i have a hp stream 14-cb101nf
                  serial number : 5CD0221YD2
                  motherboard number A0P9KMB6C1
                  the problem is the laptop turn on but no display and the caps luck blink 3 long and 2 short and when look it up on the hp web site it show bios problem related
                  can some one pls fix the bios image thanks in advance
                  • peste
                    • Dec 2016
                    • 12859
                    • ROMANIA
                    you have everything you need at post #4
                    https://www.badcaps.net/forum/troubl...a0#post3279645
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • haitham sharabati
                      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                      by haitham sharabati
                      Hello engineers 😀,
                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                      💀 Problem:😅
                      - Device shows “Administrator Password”...
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • DynaxSC
                      by DynaxSC
                      11-17-2023, 10:56 AM
                    • MDSI
                      HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                      by MDSI
                      I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                      Details:
                      Model : HP OMEN 17-an012nf
                      Motherboard Part Number : DAG3BAMBAF0 REV : F
                      Serial Number (S/N) : 5CD7280D51
                      BIOS chip : Winbond W25Q64VSIQ
                      Programmer : EZP2023+
                      Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                      I already...
                      07-28-2025, 07:11 AM
