BIOS HP 14-ax113la DA0P9MB26A0
  • karlox
    • Dec 2017
    • 136
    • México
    Hello! Greetings, can someone help me check the BIOS backup programming of this laptop? I backed it up with NeoProgrammer, but when I transferred the code to the chip, the device's power LED turns on and then immediately turns off. The tragic thing is that it was working; I made a backup because I replaced a chip that was causing the battery not to be detected. I tested the device and it worked, the battery was detected. However, as a method I sometimes apply when working with devices with power issues, I erased the BIOS IC and reprogrammed it, but this time it failed. I downloaded the BIOS from HP, but none worked; some only emit a quick light on the screen and then turn off. Checking the power consumption, I noticed that once the chip was reprogrammed, it only drew 0.02 amps, whereas with others, it reached 0.09 amps. What did I do wrong? Thanks in advance, greetings.
    HP Stream 14-ax113la
    MB DA0P9MB26A0 Rev. A
    SN# 5CD1495JDV
    Celeron N4020​
  • LEO037_2029_
    BIOS_LEGEND
    • Nov 2023
    • 83
    • Argentina
    HI try this bios. i download from the page and i add DMI info , try and good luck. and tell me if work for you
    • karlox
      • Dec 2017
      • 136
      • México
      Thanks, but it doesn't work. I have a flashing power LED and it immediately turns off, thank you.
      • peste
        • 13258
        • ROMANIA
        SN# 5CD1495JDV
        Celeron N4020
        bios extracted from the HP site update for..
        HP Stream Laptop 14-ax113la (2M6L0LA)
        DMI 3C7000 - 3C8FFF
        KEYWIN 3C5000 - 3C503F​
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
          by Vesko356
          08-11-2023, 03:27 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • Wahaz
          by Wahaz
          10-30-2023, 08:42 PM
