L505-13T bios problem
  • soltaan
    • Dec 2018
    • saudi arabia
    Dear sirs ..
    I Had a problem in my laptop after updating bios to 2.1-win .. the laptop turns to black screen with a dash in the up left corner and not booting from HD or CD
    is there any way to revert to the old version of bios
    the lap top is Toshiba L505-13t
    Main board : NSWAA LA5322P rev:1.0
    could you help me please how to repair it ??
    please send me to my email
    soltaanalmilaah@gmail.com
    because I'm using my friend laptop for 3 days searching for solve
    thanks for your concern
    • 20633
    Re: L505-13T bios problem
    Make a crisis recovery drive and try to flash bios.If it doesn`t work you need to clear the cmos.Remove the battery and dismantle the laptop ,remove the top case.Desolder plus side of the cmos bios battery and lift the leg or put a piece of card under it, then place the top case on,but don`t clip it down.Attatch the power button ribbon cable, with no adapter or battery press and hold the power button for 1 minute. Resolder the cmos battery, connect power button cable again and also the keyboard, and try to start with adapter , tapping f2 to enter bios. If it doesn`t enter bios or start you will have to flash the bios with a hardware bios programmer .
    • soltaan
      • Dec 2018
      • saudi arabia
      thank you very much for your help
      programming finished my problem
      THANKS THANKS THANKS
      • AquaMan Ua
        Problem with PANASONIC CF53 laptop after changing BIOS settings
        by AquaMan Ua
        Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
        05-17-2025, 09:40 AM
      • traxformania
        TONGFANG "GM7TG7P" Bios Password Problem?
        by traxformania
        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
        I'm trying to reset my bios without success.
        I tried :
        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
        11-15-2023, 07:32 AM
      • trouble55
        NEC VersaPro PC-VRT42FBFR22B BIOS problem
        by trouble55
        Hi All,
        [Mother board model]
        V-VE212(U3E1)
        [Serial number]
        24000135PA
        [BIOS chip model]
        Macronix MX77L12850F
        I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
        I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
        I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
        09-19-2024, 01:24 AM
      • toti24
        (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
        by toti24
        dell precision m4600 laptop
        i7 2760qm
        8gb ram 750gb HDD
        intel hd 3000 integraded and nvidia quadro 2000m
        pleasea bear with me english isnt my language and ill try to be as clear as possible
        note i live in mexico in a very small town..
        thank you.
        laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
        the brick happened when i was installing win 10 using usb.
        used rufus and officia microsoft.iso
        it finished copying files from usb...
        03-06-2022, 08:39 PM
        by Vesko356
        08-11-2023, 03:27 AM
