Toshiba U945-S4390 - Need assistance understanding BIOS and EC flashing
  • mattpd
    • Oct 2012
    • 302
    TLDR: I need to flash the BIOS and EC on this laptop. There are 3 files. Two BIOS files that I know how and where to flash. But I don't know what to do with the 128kb EC BIN.
    I have an issue with this laptop that I have never experienced before with any other laptop.
    It was working OK on Windows 8, which is the OS that it came with.
    I went to upgrade to Windows 10, and immediately upon reboot the screen went black, but the laptop would still power on.
    I tried all the normal fixes like pulling the battery and holding the button. Known good RAM in each slot. External monitor, and a few other things, but nothing worked. Every time you turn the laptop on, the fan spins and the power LED comes on, but the screen never turns on.
    I thought maybe I was just really unlucky and I have a motherboard failure while installing Windows 10, but to my surprise, many other people on the internet have had the EXACT same issue. They had a working laptop, tried to upgrade to Win10 or tried to do an OS "reset" and afterwards their screen would never turn on again. I am not sure if I am allowed to link to other forums here, but I found at least 6 people with the same problem. One person it happened to on the same day he bought the laptop, after he tried to upgrade to Win 10. So, obviously, there is some major issue with these boards when you try to update the OS.
    One person said he solved the problem by re flashing the EC so I want to try.
    Here is where my inexperience shows...
    If you look on VinaFix and even on BadCaps, someone has posted the BIOS and EC for this laptop. It comes in three files.
    One of the files is U940_PSU6SE_UH4_25Q16CV.ROM. I assume this is to be flashed onto the IC labeled UH4. I already did this with my SPI programmer.
    And another file called U940_PSU6SE_UH3_25Q32BV.ROM which I assume will go onto IC labeled UH3. I also already flashed this one too.
    But what about the 128kb BIN for the EC? Is there a third IC somewhere that I need to flash with EC BIN?
    If anyone could clarify how to "flash the EC" that would be great.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Toshiba U945-S4390 - Need assistance understanding BIOS and EC flashing
    the 128kb file should be programmed into the KBC chip. programming this chip needs a special programmer. what is the programmer which you have?
    However, it is a question why an OS upgrade may lead to EC failure. I think it is hardly possible.
    • mattpd
      • Oct 2012
      • 302
      Thank you. I just have a USB SPI programmer. The Ezp2011. Is there a way to adapt this programmer to flash a KBC? I will get another programmer if not.
      I also find it hardly possible, and I know it sounds dumb. I would have never thought about a BIOS or EC failure until I saw all the other people on the net with the exact same issue. At least 6 people with the same MOBO could not get their laptop to show a display ever again, no matter what they tried, and it started immediately after a Windows upgrade.
      I asked around in another group that I am a member of, and one person said he has seen a similar situation when trying to upgrade legacy laptops to Windows 10. According to him, at some point during the OS installation it does touch the BIOS and makes modifications if the laptop was Windows 8 or older. 99.999% of the time there is no issues.
      This information, plus the one person on the net that said an EC reflash brought his back to life, leads me here...
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        your programmer is not able to program KBC. If you always repair laptops, you should buy a KBC programmer anyway. Now, you should wait for experienced members of this forum to give their opinions on this issue. they will guide you what is the best KBC programmer now.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3636
          • slovakia
          or replace kbc from the same model
          • technician37
            • Aug 2018
            • 30
            • philippines
            anyone here have dump bios U945_S4390
            VCUAA LA-9161P REV.1.0
            Thank you in advance..
              • 22276
              https://www.badcaps.net/forum/showthread.php?t=48217
              • lpraderi
                • Dec 2017
                • 31
                • Uruguay
                You can also flash ENE KB9012QF with BusPirate or CH341A hardware and Flashrom software.
                http://dangerousprototypes.com/docs/...ith_Bus_Pirate
                http://www.flashrom.org/Downloads#In...on_from_source
                Pay attention to flashrom version , only building from recent git you have ENE KB support.
                git clone https://review.coreboot.org/flashrom.git
                • kenkaniff
                  HP Pro x360 Fortis 11 inch G9 Doesnt boot after flashing bios
                  by kenkaniff
                  Product Name: HP Pro x360 Fortis 11-inch G9
                  System BIOS: U94 Ver.01.08.00 10/06/2023
                  Serial Number: 5CG31946F5
                  SKU Number: 85W05EC#AK8
                  Motherboard: ANOLE10-MV-TRIPOD / 6050A3332901-MB-A01 / 2021-11-09
                  This motherboard has 2 similar chips. One is on the front marked with BIOS SKT "Winbond 25Q256JVEN" and one on the back marked with U351 "Gigadevice 25B256EYIG". I ignored the one on the back and only desoldered front chip. Made a backup, made sure the reading was the same with another 3 backups.
                  I needed to remove bios password...
                  10-01-2025, 04:32 AM
                • bql
                  In search of advice for flashing bios via efi shell
                  by bql
                  Hi Badcaps,
                  I'm having the same Notebook and problem as in this topic:
                  HTML Code:
                  https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/3601016-need-bios-for-clevo-pd50pnp
                  I'm assuming that flashing the provided bios in this topic would solve my problem.
                  The only thing i can boot to is EFI shell
                  How do i flash the bios image in the EFI shell ? / Can i use any flash.nsh or is the executable interconnected to the bios image? ( i cannot find any bios related files in the internet...
                  11-26-2025, 05:21 PM
                • istvanszasz99
                  Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                  by istvanszasz99
                  Product Name: Razer Blade 15 (2022)
                  Product ID: RZ09-0421
                  Motherboard: CH580
                  BIOS Versions I work with: 2.02 & 2.06
                  Bios File Size: 32,768 KB
                  Dear Forum Readers!
                  I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                  I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                  The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                  !!! MY RAZER BLADE...
                  11-24-2025, 05:52 PM
                • Timeeez
                  X270 - Bios flashing help
                  by Timeeez
                  I am still a beginner and want to learn more about flashing bios. First of all, thank you very much for the tutorials made on this forum it helps a lot.
                  Lets get straight to the point. When I try to flash the bios of my Lenovo X270 it restarts several times and always returns to the bios that was there at the beginning. When I get the bios from someone on the forum and write it to the bios chip, I always have the same serial numbers. I have the feeling that the pc is reflashing itself. Where could this come from? How to avoid this problem?
                  11-30-2022, 05:17 PM
                • zenius
                  by zenius
                  12-08-2024, 06:13 AM
