Ga-ahm5h rev 1.1 bos needed uregetn plz
Ga-ahm5h rev 1.1
Tags: None
Re: Ga-ahm5h rev 1.1
The only place i found the bios was here: https://nottecreparos.com/showthread...5632&styleid=2
I don`t know if its free to download, you can register and find out .
If you can`t get the bios,try cleaning the ME area of your bios backup .Comment
This mobo same with Olivetti Olibook s1350, or SP13R??
https://www.ebay.co.uk/itm/SCHEDA-MA...-/173195192621
Check here:
ftp://50.236.239.153/Notebook/SP_Ser...OS(F6)_EC(10)/
i dont know this same bios or not with your model, because you not post your backup...Comment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
- Loading...
