I have one thinkcentre M92z,no power,green led only.There is lcdinput,the monitor menu is active.Does somebody have a full dump(EC-U36-u17)?
Thinkcentre M92z bios dump
by AhariHi all,
I...-
by tapialeorockHi, i'm looking for a TC m83 tiny type 10E9 with IS8XT v1.1 board bios dump.
I somehow messed up with my bios image and the lenovo boot logo was replaced with nec logo.
Lenovo's driver lookup tool is unable to recognize my computer in windows also.
Changing the serial number manually with amidedos tool hasn't fixed the driver lookup issue.
I have tried with thinkcentre m93p and m73 bios dumps, but none of them restored the lenovo boot logo nor the driver lookup issue.
I'll leave my current bios dump.
Thanks....-
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
- Loading...
