Thinkpad L560 Bios Password
Thinkpad L560 Bios Password ?!!
Possible to unlock it from eeprom ??
Lenovo L560 - bios PWD
Re: Lenovo L560 - bios PWD
Has anyone been able to unlock/reprogram one L560 with bios PWD
Ive reprogrammed BIOS, KBC and still have bios locked
When the PC boots up the first time after bios flash I get this error
0183: Bad CRC of Security Settings in EFI Variable.
Could it be the security chip preventing the unlock??
Jeezz what a nightmareLast edited by magneh; 03-13-2019, 04:36 PM.Leave a comment:
And they are completely right...theres a little switch on the board that the cover push on when in place... some reset signal that prevents 3.3V on the board.
So just need to put some tape on it and I have 3.3V on the bios, and both laptops booting up, still with Bios PWD.
I feel like a donkey right nowLeave a comment:
which programmer do you use?
Do you use a clip or desolder the chip?
I made the observation that sometimes (with clip) some bytes aren't written correctly.
I mainly used SkyPro II ... and from time to time TL866 II (should be better, but can't be used with clip)
Try desolder the bios chip and check whats happen in this state and reprogram the chip with your old bios dump.
I have 2 working L650 with bios locked.
The 3.3V are not coming up after I de soldered the bios, re programmed with the dump posted here, and soldered it back.
Since then machine is dead. No reaction at all. I can confirm the 3.3V are not present in pin 8 of the bios.
I use a SP8-a programmer with the 8 pin adapter for the bios.
Used directly on the programmer.
I can confirm there is no damage on the bios pads or surrounding area/components.
I did the same thing to a second L560. Same result. machine dead since then. Very weird...
Ive measured the Bios pins in diode mode of a working and a non working L560.
I can see considerable differences in certain pins.
pin working L560 L560 KO L560 KO without
bios chip
1 .693 .654 .586
2 .560 .544 .542
3 .736 .580 .624
4 0 0 0
5 .727 .610 .631
6 .590 .565 .631
7 .727 .598 .626
8 .357 .363 .360
But even seeing this, this wont justify the 3.3V to not be present AFAIK...
Seeing this, what would you more experienced guys do?
Thanks for any inputsLast edited by magneh; 03-12-2019, 12:58 PM.Leave a comment:
I may be wrong, but customers have reported that some Lenovo ThinkPad models need bottom cover to be installed, otherwise bios chip won't get +3.3V... worth a try.Leave a comment:
Try desolder the bios chip and check whats happen in this state and repgramm the chip with your old bios dump.Leave a comment:
Yes, but the thing here is that the 2 laptops I flashed with the PWD clear dump, they both behave the same way.
No power at all.
In one of them I rolled back to original dump, and still the same.
So its weird as I have the same problem with both. No power after bios programming.
Im sure the 3v line is not shorted, as the diode mode measurements showed in BIOS chip IC pins.
I will do some checks when Im at the office.Leave a comment:
Check for resistance to gnd on 3 and 5v coil to begin with. 0V at kbc means probably your 3v rail is shorted somewhere. Can be 'coz of KBC but there can be "N" number of reasons for 3v rail to pulled down.Leave a comment:
Oh dear...
Remember I said both laptops I flashed with the clear Bios did not turned on after?
Just rolled back the dump to the original one, and still no power, nothing.
Quick measurements, 20V entering in the DC jack.
Bios chip Ov in all pins... no good...
No knocked components, bios chip well soldered, no shorts.
What could be the cause for this? KBC chip ?
Kinda lost now...Leave a comment:
Do you know where I could by some programmed KBC's for this particular model?
Once again, thanks for your time!
CheersLeave a comment:
Pre-programmed kbc means the kbc is already flashed with dump specific to that mb. So no need to flash kbc on your end assuming the kbc you buy is ok and correct program is flashed. I advised so as you said you dont intend to use it frequently. Else go for svod3. Its a good investment.Leave a comment:
Hi there!
Thanks again for your feedback.
When you mean to look for pre-programmed KBC for this model, you mean the programming for the IC right?
Is this coming with the software of the programmer? or should be downloaded?
Sorry for all the questions again.
PS : I think I can get the SVOD V3 for 150€. maybe its a good investmentLeave a comment:
The programmer in your link is probably Vertyanov which is also a good choice. I dont know about the price difference between svod and Vertyanov in your country. You can go for it or if you dont intende to use it frequently -look for pre-programmed kbc for your model.Leave a comment:
Hi there,
Yes, SVOD seems to be a nice programmer.
As I dont do these jobs too often, do you think the one I referred could also do the job?
Or SVOD is a much better investment long therm wise?
Thanks,
Jose ReiLeave a comment:
Yes, just program the kbc. Svod is a good choice.Leave a comment:
Hi!
Thanks for the info!
So no need to do anything with this chip I've been trying to re program?
Just reprogram the KBC then?
Can you send me a link or recommend a good KBC programmer for this?
would this one be a good option?
https://www.ebay.com/itm/ITE-ENE-IO-...:pf:0&LH_BIN=1
Thank youLast edited by magneh; 11-14-2018, 09:20 AM.Leave a comment:
The password is stored in the npce388. You will need a KBC programmer as mcplslg123 said .Leave a comment:
I will roll back the bios with the original backup and test it tomorrow.
I dont have a KBC programmer unfortunately.
Could this be an issue to unlock these laptops?
I will update the thread tomorrow.
Thanks!Leave a comment:
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by jendkkd jejeSo a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...10-11-2024, 03:12 PM -
by 1g0rHello everyone,
First, the data in brief:
Manufacturer: Lenovo
Model: ThinkPad L15 G3 21C3-0016GE
motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
IC Bios 1: MX77L25650F
IC Bios 2: MX25L25673G
EC Chip: NPCX997KAABX
So far I've been a silent reader, but now I need your help
I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge - Loading...
