asus s400c bios needed
  • Romy2018
    • Sep 2018
    • 174
    • japan
    I need help to repair this original bios of ASUS S400C board id:S400CA REV.2.1.
    client told me that laptop becomes dead after updating os to windows 10. I measured voltages is present,there is 3v and 5v on the coil, and also there is 3.3v on power button and on the bios chip pin3 0v pin7 and pin8 have 2.9v.I already tried flashing the bios i found here in this forum, but still the same issue laptop is dead pressing power button nothing happens.but when i plugged the battery and plugged the charger charging light orange is present but pressing power button nothing happens.I have upload my original bios dump, can someone help me to fix this please
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    Re: asus s400c bios needed
    Try Asus S400C fix first, if doesnt work try second if then not working then I dont think the BIOS is the issue here.
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      Originally posted by romy2018
      i need help to repair this original bios of asus s400c board id:s400ca rev.2.1.
      Client told me that laptop becomes dead after updating os to windows 10. I measured voltages is present,there is 3v and 5v on the coil, and also there is 3.3v on power button and on the bios chip pin3 0v pin7 and pin8 have 2.9v.i already tried flashing the bios i found here in this forum, but still the same issue laptop is dead pressing power button nothing happens.but when i plugged the battery and plugged the charger charging light orange is present but pressing power button nothing happens.i have upload my original bios dump, can someone help me to fix this please
      bios
      • Romy2018
        • Sep 2018
        • 174
        • japan
        tried flashing bios above file still the same issue pressing the power button nothing happens.anyone please help on this
        • Romy2018
          • Sep 2018
          • 174
          • japan
          need help on this please, when i plugged on the bench lab supply is taking 0.03amps.
          • Romy2018
            • Sep 2018
            • 174
            • japan
            and i noticed when i plugged the charger the chip that has a marked JC EF is warm.
              • 22275
              The IC marked JC is a richtek RT8239B . Datasheet: https://cdn.badcaps-static.com/pdfs/...0d40ffc6d4.pdf
              http://*******/viewtopic.php?f=40&t=57074
              Boardview attatched .
              • Romy2018
                • Sep 2018
                • 174
                • japan
                thanks i cannot find the same ic can i replace this ic with RT8223MGQW?is it compatible?
                  • 22275
                  Do you mean you can`t find the IC on the board or online to buy ?
                  https://www.ebay.com/itm/3pcs-RT8239...p/401541431830
                  I don`t know if the RT8223MGQW is compatible,you`ll have to find the datasheet and compare the 2 IC`s .If in doubt get the original part .
                  • Romy2018
                    • Sep 2018
                    • 174
                    • japan
                    no i found online the same ic but the problem it takes time to deliver.client in a hurry i have onhand ic RT8223MGQW i just want to know if it is compatible replacement for this
                      • 22275
                      No, not compatible. The RT8223MGQW has 24 pins for a start .
                      • quezon
                        • Dec 2015
                        • 70
                        • Philippines
                        thanks
                        • pirati
                          by pirati
                          10-27-2025, 04:20 PM
                        • grimacelord
                          by grimacelord
                          07-10-2025, 02:52 PM
                        • jbonavita
                          by jbonavita
                          Some issues
                          Things I tried
                          04-29-2025, 09:38 PM
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
                        • ArkzG
                          [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                          by ArkzG
                          Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                          What I currently have available:
                          - Model: FA506NF (2021)
                          - BIOS chip: GD25LQ16 (16Mbit/2MB)
                          - Tools: CH341A programmer ready to use
                          Does anyone have either a clean 2MB .bin dump of this model,...
                          09-26-2025, 09:34 PM
