Need bios HP 14-b039TU
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    I need bios of HP 14-b039TU, code board DA0U33MB6D0 REV. D
    Please share
    Thank you
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Re: Need bios HP 14-b039TU
    or clean me my bios
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Your main bios me region is corrupt. Here is your bios fixed and cleaned. Report result.
      • cyngo
        • Jun 2015
        • 219
        • Indonesia
        Thank you for your help. but my laptop still has no display
        do you have bios file for this type?
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          here is your bios
          virgin file from hp support site
          i have inserted you serial and model nr
          flash and report back pls
          main bios should be ok but i dont know will ec bios need some work so test and report back
          Im Back... sort of...
          • cyngo
            • Jun 2015
            • 219
            • Indonesia
            Originally posted by ala_borbe
            here is your bios
            thank you very much, but the problem is still the same
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              well you havent stated what the problem is, symptom or the history of laptop... you requested the bios, and bios i posted is ok. problem may be elsewhere
              • cyngo
                • Jun 2015
                • 219
                • Indonesia
                the problem began with a dead laptop. By replacing the IC power, the laptop is on. before I did all that, first my bios backup. after on normally, for some reason suddenly the laptop becomes no display.
                before I do a more complicated job like reball pch, it's a good idea to flash the bios first. because before I got a case like that and succeeded in flashing bios with the original file from the official site.
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  yes, makes sense, i follow steps like that. however problem is elsewhere.... not bios
                  • cyngo
                    • Jun 2015
                    • 219
                    • Indonesia
                    well, i will try again. if problem solved, i will share it here. thanks a lot
                      • 21836
                      There are 2 slightly different bios`es for this model.The EC has a few differences too.Its possible you might have had the wrong version flashed in the first place.
                      Try these bios and EC , flash both bios + ec from each.As ala_borbe said, if the bios don`t work the problem is elsewhere.
                      • cyngo
                        • Jun 2015
                        • 219
                        • Indonesia
                        I've tried both, and the results are the same. thanks a lot.
                        • cyngo
                          • Jun 2015
                          • 219
                          • Indonesia
                          but there are differences in results between using the backup bios and other bios provided here. by using the bios of the backup or original from the laptop, when plugging the flashdisk, led on flashdisk blinking like a process is being run. if using other bios is not the case, led on flashdisk does not blink.
                            • 21836
                            Well , @mcplslg123 cleaned your original bios, @ala_borbe gave you an official bios, and ive posted 2 bios straight from hp . What is the motherboard code , if its DA0U33MB6D0 REV. D then all the bios`es given to you by the members should have worked ,but only if the problem is with the bios.
                            • Bloodhoundje
                              by Bloodhoundje
                              03-16-2024, 03:12 PM
                            • TripTop
                              Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                              by TripTop
                              Hi
                              i have dell latitude E7270 with following symptoms:
                              - takes long time to restart.
                              - sometimes powers on and then off
                              - sometimes while working it just dies,
                              From googling online bios clean could possible resolve this?
                              i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                              As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                              I reinstall...
                              09-09-2024, 02:05 PM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • grimacelord
                              by grimacelord
                              Hello there.
                              History:
                              03-15-2023, 03:29 PM
                              by Vesko356
                              08-11-2023, 03:27 AM
