need sony pcv-ae1l bios dump
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    hello everybody,
    need bios bin of this sony
    main board MBX-200
    THANK
  • alas3376
    • Nov 2011
    • 382
    • BENIN
    Re: need sony pcv-ae1l bios dump
    Hello !
    Help Help Help....
      • 22286
      There is no MBX-200 .You mean a PCV-AE1L - VGC-RT100Y .
      Try this bios .
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • robgerr
        Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
        by robgerr
        Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
        Attach...
        11-17-2023, 09:52 AM
