Asus X555l some Keys not work (x555ld 3.6 mainboard)
  • robgerr
    • Apr 2012
    • 70
    • Italy
    Ho forum. This laptop have a problem with keyboard. Some Key not work. I try to replace keyboard but problem remain, same keys not work. With external USB work perfectly. I try to resolder pin of keyboard connettore but nothing. My suspect is a Ec ite8585. Anyone have a dump for this model?
    P.s. try to reprogram main bios with dump from this forum but nothing.
  • mielta
    • Apr 2015
    • 368
    Re: Asus X555l some Keys not work (x555ld 3.6 mainboard)
    Hi
    Make an Backup and try this
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I faced this issue on a compaq CQ58 motherboard where i even replaced KBC. All resistors checked and found ok. No corrosion either. Checked voltage on all pins of kbd connector and compared the same with a fully working mb-No difference in measurement. I could'nt figure out why some keys were not working and delivered it back to customer as he agreed to live with this defect. I doubted on PCH though.
      PS: Your case may be different.
        • 22279
        Which keys aren`t working. Have you tried re-installing the ATK driver .
        • BremiX
          • Oct 2017
          • 64
          • Latvia
          I had this issue too but another Asus laptop. Resolved it with BIOS update.
          • robgerr
            • Apr 2012
            • 70
            • Italy
            Replaced Kbc Ite and now keyboard work perfectly. Very thank's guys
            • fox01fox02
              • Oct 2015
              • 28
              • iran
              Goodluck
              • TheJeanox
                HP x360 14-CD Laptop 3 keys not working (G/H/ESC/) Help please!!
                by TheJeanox
                The laptop suffered a liquid spill which caused the keyboard to be damaged (the liquid did not reach the motherboard).
                I bought the replacement part, when I tested it before assembling it I realized that the aforementioned keys do not work but the keyboard is fine, it was tested on another computer and indeed all the keys work.
                On pin #32 of the keyboard connector there is a voltage of 3v, when pressing the keys that do not work the voltage drops to 1.3v~1.5v but if I press any of the keys that do work the voltage does not drop, at this point I can no longer understand...
                11-07-2024, 12:40 PM
              • Mirenia
                Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                by Mirenia
                I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                03-30-2025, 06:47 AM
              • carso
                X555LD Rev2.0 No Power No Mainboard Could you help
                by carso
                Hello there
                X555LD REV 2.0 i7 4510u processor
                I closed and moved it while working, when I tried to open it again, there was no response
                I took the motherboard out and tested the power line with a multimeter
                I/O was heating up, we tried plugging in another chip, now the same chip doesn't heat up but still no power
                They said the processor south passed away but I want to be sure. What check should I do with the multimeter?
                08-31-2022, 03:32 PM
              • orcic
                MASTER TL240 and new mainboard LW36BKC01
                by orcic
                I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                Now I have some doubts about how to connect the new mainboard to the old power supply.
                First of...
                05-12-2023, 08:10 AM
              • Malva
                Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                by Malva
                I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                Mainboard model: EAX65684604
                PCB marking: EBT62954607
                SPI chip: Winbond W25X20CLNIG Problem description:
                Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                • I bought another
                06-25-2025, 02:07 PM
