Pegatron - Turbox A15YA BIOS needed
  • memoslar
    • Apr 2015
    • 122
    • Greece
    I am trying to find Turbox A15YA BIOS. Its a pegatron motherboard clone.
    Can someone help?
    Old bios is 8mb.
    Motherboard had a short. I replaced 4 mosfet. Now its on but it stays on logo screen.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Pegatron - Turbox A15YA BIOS needed
    upload the original Bios to check. It is possible that it be a non-Bios issue such as HDD.
    • memoslar
      • Apr 2015
      • 122
      • Greece
      I have replaced the disk but still stays in logo. When i was entering into bios it recognized successfully the hard disk and every usb flash drive.
      I tried to reprogram it with the same bios in different chip but it didnt turn on. Then i found a different bios from a different model a15ya motherboard,i programmed and now it turns on with black screen.
      I must find the correct bios...
        • 22035
        Your bios ME area is corrupt.If your motherboard revision is 2.1 check these bios dumps: https://www.badcaps.net/forum/showthread.php?t=44558
        • memoslar
          • Apr 2015
          • 122
          • Greece
          I tried that version of 8mb. It starts with black screen. It is incompatible.
            • 22035
            Try this one, its for a gigabyte Q2542,same pegatron board.
            • memoslar
              • Apr 2015
              • 122
              • Greece
              This worked! i have screen.. But still stays at logo screen...
              In bios menu everything looks good.
              The motherboard had 4 shorted mosfets before around the cpu...
                • 22035
                Look at the pdf on post #1 here,it may help : https://www.badcaps.net/forum/showth...ghlight=casper
                • georgeathens
                  • Jan 2020
                  • Greece
                  Can someone help?
                  Old bios is 8mb.
                  i have a working TurboX (Pegatron) A15YA, i could clone the Bios for you, if you can find me the motherbords' users manual that i need to Upgrade the CPU. It is running on a Celeron
                  B815 Sandy Bridge socket 988B rPGA @ 1,6 GH i beleive.
                  i have used this second generation I5 CPU
                  i5 3210M Ivy Bridge Socket 988B rPGA @ 2,5 GH
                  https://ark.intel.com/content/www/us...-ghz-rpga.html
                  and it worked fine, for testing purposes, but to upgrade it i want to use this I3 CPU (as it is cheaper to buy), but i am not sure that it supports it.
                  https://ark.intel.com/content/www/us...-2-40-ghz.html
                  the seller has told me that this is the batch number of the CPU, but i can't find any website that matches CPUs to their batch number.
                  J23B359
                  if you can help me, i will upload the BIOS for you. if you know of anyone that has an affordable cpu for me, also let me know
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Ivy Bridge often won't work properly in place of Sandy Bridge CPU on laptops. But if the Core i5-3210M worked properly and it didn't shut down after 30 minutes, then the Core i3-3110M will work too.
                    HM70 chipsets are compatible only with Celeron/Pentium, they will shutdown after 30 minutes with Core i3/i5/i7.
                    Batch number does not really matter, the Sspec (printed on the CPU package) will tell you what CPU and stepping it is. For Core i3-3110M on Socket G2 it should be either SR0N1 or SR0T4.
                    • kmx200
                      • Mar 2015
                      • 22
                      • Greece
                      Thank you very much! It worked for me as well.
                      My laptop had just lost it's bios without any shorted parts.
                      @memoslar I had a similar problem at first, so I had to Load Optimised Defaults in order to continue boot.
                      Thanks again
                      Stavros
                      • tlindi
                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                        by tlindi
                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                        >Read BIOS guides, methods, resources and tools
                        Ack
                        >Try the method at BIOS guides, methods, resources and tools before requesting help
                        Ack
                        >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                        python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                        01-30-2025, 04:26 AM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                      • ali0606
                        Casper (Pegatron) A15HC, A15YA, A15HC UMA Bios
                        by ali0606
                        Hello everyone. Unfortunately, it is very difficult to find this in many sources on the internet.
                        Available on most paid sites. I am sharing these for you by pulling them from original working computers.
                        The 15YA bios version works on all PCs, it is the version used only on the card with USB 3.0, which is the upper version of the 15HC model, but it works without any problems on the card with A15HC nvidia GPU. Other versions are the UMA version that fits with Nvidia gpu and OB vga or with Nvidia gpu canceled.
                        The only difference is that the A15YA version requires...
                        09-13-2023, 03:36 AM
                      • DynaxSC
                        by DynaxSC
                        11-17-2023, 10:56 AM
                      • pirati
                        by pirati
                        10-27-2025, 04:20 PM
