In need dump bios Asus Model UX306U, motherboard UX305UAB REV 2.0
  • pcando
    • Oct 2014
    • 7
    • Ecuador
    Hi Guys, please help me with a working dump bios file for Asus Model UX306U, motherboard UX305UAB REV 2.0 ......Original bios file was erased by owner by mistake and can not be read.
    Thank you in advance for it.
    Regars
  • Kayra
    • May 2017
    • Türkiye
    Re: In need dump bios Asus Model UX306U, motherboard UX305UAB REV 2.0
    hello pcando
    Did you find the bios file?
    • hoaca388
      Badcaps
      • Jan 2022
      • 12441
      Regars
      Take pictures of the QR code showing UX306...or the sticker near the RAM slot, post it here.
      • GardevoirForEver
        Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
        by GardevoirForEver
        I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
        Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
        The motherboard of my ASUS...
        11-15-2025, 04:30 PM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • Dreno
        Bios for motherboard asus H81m-plus
        by Dreno
        Hi how are you
        I need this bios for this asus
        motherboard asus H81m-plus...
        11-27-2025, 07:03 AM
