hi... i need bios bin for motherboard 6050a2345301-mb-a02....Thanks...
hp touchsmart tm2-2150es
Every donation made will go towards server fees and maintenance costs.Tags: None -
Re: hp touchsmart tm2-2150es
Can you post your bios backup . -
orig.old biosAttached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Try this one, and give feedback .Attached FilesComment
with the given bios does not go through the "starting windows" and the cooler is spinning at maximum speed ... ec orig 512k ... maybe there is something wrong here the sent has 64k ..Attached FilesDue to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
hdd ok...win ok...Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Heres another bios,its fixed now, hopefully .Attached FilesComment
Hello! the initial problems were: the windows opened after 10 minutes after starting, after which the touchpad and usb did not work. when the power supply was inserted into the laptop socket, it started without pressing the start button, the cooler was spinning at full speed ... after the changes made in bios by SMDFlea, the laptop does not go into windows but stays in "start windows" and starts from the start button . the tensions are ok, hdd ok, windows ok.Original ec 512kb, not 64kb ... I sent to position 5 (# 5) original ec 512kb ..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Heres the new 512kb EC .The original EC may be 512kb but it only has 64kb of code,you can check it with a hex editor. The 64kb EC was cut from the official hp bios.Attached FilesLast edited by SMDFlea; 08-15-2018, 06:25 AM.Comment
by glovecapsHello,
I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
The reason for wanting to do this is that the keyboard isn't working as it should, and I think this... -
by AkaBukaiHi there,
I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
The little LED on the power button is flashing slowly and nothing happen.
This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
So I decided to flash the BIOS using a cheap programmer.
And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
I also... -
by DiddiAbRecently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
- Loading...
